07-06-2007, 02:02 PM
#21
Dont do this
To All Looking At This Thread Do Not Take The Relay Out And Snip The Pin, Because When You Find Out That When There Is No Light That The Car Will Throw The Svs Light You Will Be Pissed. I Tried This Mod This Past Weekend And Notice That With The Presence Of Light It Worked Fine, But Once It Got Night And I Tried Again (just A Hunch) The Svs Light Came On. Thank God I Bent Mine So I Could Put It Back.
10-22-2007, 04:22 AM
#22
can u not just take relay 20 out?
its for the auto control
10-22-2007, 04:24 AM
#23
nevermind it throws a code right away damnit
10-22-2007, 05:16 AM
#24
best way no code thrown take number 22 relay out works perfect on my 03 now i just turn them on normaly
10-22-2007, 08:55 AM
#25
Yeah I did mine on the 2000 2.4L so yeah I should have mentioned that could be different on different years. Pimp you said you took the relay out completely and it didn't throw the light on at all? I think it would throw the svs light when that relay is found missing,but if not I may try that if you are sure it works. Go a pic?
10-22-2007, 10:38 PM
#26
still hasnt thrown anything and the girl has the cam just go underhood and screw off fuse cover and look in the cover to find the 22 relay from top left its 2 over i down if something does get thrown just plug it back in but ive hadnt had problems yet
10-23-2007, 10:26 AM
#27
Yeah but you have a different Year. When I did mine I didn't realize it until it got dark. When it tried to switch it threw the light on immediately, but when I shined the flashlight on the sensor it wouldn't do it.
10-23-2007, 11:24 AM
#28
hmmmm idk
10-23-2007, 02:46 PM
#29
auto headlights still come on when u do this mod right
10-26-2007, 03:31 PM
#30
hmmmm idk
I'm not saying you are wrong just giving my experience.
10-26-2007, 03:32 PM
#31
Yes they should
10-26-2007, 03:58 PM
#32
they do at night i bent the one relay back but the other one is still out and no daytime lights
08-08-2009, 10:58 AM
#33
ok so OLD THREAD REVIVAL here ..
im putting in HID's tonight in my 9006 low beams on a 99 gls... so does the snipping method work or not? also if on the 99 the DRL are the highs would i even need to disable them since my HID's are for the lows? thanks
08-08-2009, 11:45 AM
#34
I'm not sure if 99's are the same as 2004 but I have HID's in low beam and all that I did was remove the relay completely. No problems or codes.
08-08-2009, 12:10 PM
#35
thats what i was thinking is just remove the DRL relay all together
08-08-2009, 02:38 PM
#36
Go back and read Oldsman's posts, he's got a 99
08-08-2009, 03:31 PM
#37
so basically there is no way to succesfully do it on the 99?
11-03-2009, 02:07 PM
#38
I'm prety sure there is, it's just not posted here.
11-03-2009, 02:30 PM
#39
*sigh* search button works great. i think this is the 3rd or 4th time in a couple months i've reposted this for people wondering about drl disable stuff.
http://www.aleromod.com/forums/showp...7&postcount=71
disables drl perfectly on a 99, no codes anytime, auto lamps still work.
11-15-2009, 10:37 AM
#40
How about just taking the bulbs out?... or using blown bulbs?... or sniping the +wire at the bulb socket itself?
