Old 02-26-2008, 08:17 AM   #1
goldalero99
goldalero99 is on a distinguished road
How to program a new key fob
Moderator: Please remove from this HOW-TO forum ..posted in wrong section.
I recently purchased a 1999 GL and only received 1 key fob security transmitter. If I buy another one online, the instructions say I'd have to bring it to a dealer to reprogram it at an additional cost.
I was doing some research online and came across this process. Has anyone tried this for a 1999 and does it work?
Thanks.
I just purchased a 2000 Alero and it only came with one programmed key fob. The dealer did give me another one from his excess pile but told me I'd have to take it to an Olds dealer for programming. However, I did some research and found a simple procress to program that doesn't even require a paper clip.
1. From the drivers seat ensure all four doors are closed and hold down the door lock switch to the unlock position. Hold it down while you insert the ignition key twice and the third time leave the key in.
2. Release the unlock switch. You will hear three tones. Immediatelly hold down both the lock and unlock buttons on your fob. Hold them down until you hear two beeps. It may take a few moments. Do this with each of your fobs. I did it with two. I understand you can program up to four.
3. Remove key from ignition
this article is come from tech78.com:http://www.tech78.com/auto/1999-aler...try_45569.html
goldalero99 is offline   Reply With Quote
Old 02-26-2008, 08:19 AM   #2
before you buy on on line pm BLACK he has some that he bought off ebay
key fob thread
Old 02-26-2008, 08:31 AM   #3
goldalero99
key fob thread
Sent him a PM. Thanks.
Now if I can get it programmed for free, that would be even better.
Old 02-04-2009, 09:48 AM   #4
kevin1114
kevin1114's Avatar
kevin1114 is on a distinguished road
does this method work on a 2003 Alero?
Take Life's Curves Sideways, and Drift!
kevin1114 is offline   Reply With Quote
Old 01-04-2010, 10:48 PM   #5
white04alero
white04alero's Avatar
white04alero has a little shameless behaviour in the past
more info on this please dudes.
i have an 04 and i NEED to get my 2 new key fobs goin. but if it costs $50 a pop, i can live with my key.
2004 Olds Alero GL1 3400 V6
- pioneer 4900iB head unit
white04alero is offline   Reply With Quote
Old 01-04-2010, 10:51 PM   #6
white04alero
nevermind.
used the amazing search button, found out this does not work for an 04. i have to have a dealer do it.
thanks anyways people.
