Old 07-17-2008, 02:05 PM   #61
bizarre179
bizarre179's Avatar
bizarre179 is on a distinguished road
Send a message via AIM to bizarre179
Thanks! I Just took out the bulbs, and put leds in their place. I think I have the easiest third brake light out there apart from the clear lense (which is pretty easy as well).
I am going to resize the pics right now too and edit the post. I was too tired last night.
kim<3
http://www.cardomain.com/ride/2981709
bizarre179 is offline   Reply With Quote
Old 07-17-2008, 03:11 PM   #62
But how did you do the clear lens?
Old 07-18-2008, 01:15 AM   #63
bizarre179
bizarre179's Avatar
I cut the red one out and kept the clips that snap into the bracket. Then I cut some lexan to fit it and used silicone to seal it.
kim<3
Old 07-18-2008, 10:30 AM   #64
Thanks sounds easy enough, but did you have any problems with any type of contouring, or does it just lay flat. When you say cut, do you mean if it doesn't work then I'm screwed cut, or cut as in taken out?
...hey do you remember the thickness?
Old 07-18-2008, 10:40 AM   #65
bizarre179
bizarre179's Avatar
It is just flat. And when I saw cut, I mean you screw up, you better go find a new piece or try to salvage your ruined one with epoxy. I am pretty sure it is 1/8 inch thick (or something real close to it).
kim<3
Old 07-18-2008, 12:02 PM   #66
Cool Thanx
Old 07-18-2008, 12:38 PM   #67
bizarre179
bizarre179's Avatar
Sorry, it is 3/32. Anyways it is non yellowing and non breakable... so it says. Home depot for $14.
kim<3
Old 07-18-2008, 02:35 PM   #68
Thanx again cause I was wondering where I could get it from.
Old 08-11-2011, 04:25 PM   #69
Bumb for reference.
Old 08-11-2011, 08:08 PM   #70
hok666
hok666 is an unknown quantity at this point
have it stickied!
hok666 is offline   Reply With Quote
Old 08-11-2011, 08:33 PM   #71
I know, right? I'm thinking about taking it apart and redoing it sometime soon.
