08-13-2005, 04:58 PM
#41
Originally posted by sound_xtreme+Aug 13 2005, 12:12 PM--><div class='quotetop'>QUOTE(sound_xtreme @ Aug 13 2005, 12:12 PM)</div><div class='quotemain'><!--QuoteBegin-bigd6983@Aug 13 2005, 11:16 AM
and only one of them would compress back up and it only went 1/3 of the way back up and that took it 2 hours to go that far so needless to say they were shot.......
they arent really supposed to much. they are nothing like the kyb's. kyb's are gas charged, very different.
[/b][/quote]
they didnt at all, except for that one and it was super super slow......like i said they were shot, stock ones for 93000 miles........along with how long the eibachs were on there......definately time
11-26-2005, 03:58 PM
#42
Two things when changing springs:
(1) I have no idea how you are gonna get the plate above the spring off the strut without an impact gun.
(2) Ok. Don't laugh. But remember to tighten your lug nuts when finished, if you dont youll be in for one hell of a ride I will never forget.
12-25-2005, 06:42 PM
#43
just wondering if there is any way to get those pictures to work again so I have a reference. thanks
01-06-2006, 08:40 PM
#44
bump?
04-09-2006, 04:15 PM
#45
My hat goes off to Sound extreme for writing an excellent how to. I used this and finished my project in no time. Definetly helped having an impact gun. You the man dood.
Wrightie
04-10-2006, 06:05 AM
#46
dont forget to thank me also...... i was the second pair of hands in the pictures
joelsoundxtreme: u faggot
04-10-2006, 09:23 PM
#47
well then I guess I owe you a friendly thank you as well.
Wrightie
04-11-2006, 06:00 AM
#48
would this how to also help when trying to change the upper strute plates?
2006 Toyota X-Runner
04-11-2006, 10:00 AM
#49
yes, however, if you're still on stock springs, you WILL need a spring compressor, and they aren't very fun at all.
04-11-2006, 12:20 PM
#50
yeah, they can be a little tricky. The tool is rentable at most parts outlets, or they can be bought cheap at places like Princess Auto/Harbour Freight. Before I bought a set, when I changed mine I took them down to a friends shop who has a strut tamer. (larger machine for changing springs) which will compress the spring/strut assembly all at once.
If you go with the spring compressor, make sure its attached right, nothing worse then it coming off or swinging around and taking out appendages.
05-06-2006, 02:01 PM
#51
I noticed a lot of people have had problems with their old struts...my car only has 20,000 miles on it. is it necessary to change the struts now?
06-02-2007, 12:00 AM
#52
great how to written here.
now my question is what the guy said about cutting the bumper a 1/2 inch, so the the strut doesnt bottom out really neccesary? its a bumper its supposed to be there just for that.
and second i have intrax springs do i really have to install washer or spacers so i dont damage my mounts?????
any help would be greatly appreciated...
06-02-2007, 12:14 AM
#53
bro if u make another post asking about springs im gonna faking kill you with a gun
04-30-2009, 05:08 PM
#54
Mike2002: id like to add somthing to the how to, also, maybe the admins or mods could erase some of the garbage up above......
When you take your strut assembly apart, inside the strut "boot" there is a white rubber spacer, id guess about 2-2.5" tall. remove this from the strut boot. this is your strut bumper. take a hacksaw, or somthing, and cut it at the first indent from the bottom. this should make the bumper about 1/2" shorter than it was before. then re-install it. do this when installing drop springs like springtech/intrax or anyspring that drops it 1.5" or more. when disassembling my springtech/kyb combo, i noticed my bumper had hit the bottom of the strut a few times. this is because the strut is more compressed to begin with, and can bottom out because of this, cutting this bumber gives the strut more "play" before it bottoms out.
also, and this is BIG. it seems that some kyb's do not come with a nut thats as tall as the stock strut. because of this, the kyb nut will not hold the mount to the strut. it seems newer mounts have a 1/2" spacer to compensate for this, some do, some dont. make sure if installing kyb struts, you either have that 1/2" spacer on top of your mount, or you get some washers and put them below your top nut, you can and WILL ruin your strut mounts without it. i didn't have that spacer, and ruined my strut mounts.
does the spacer thing only apply to the front struts, or the rear ones as well? I just got my struts, and only the front ones came with a spacer, the rear ones just the nut.
05-05-2009, 11:05 AM
#55
can you put spacers after dropping???
Take Life's Curves Sideways, and Drift!
05-05-2009, 11:52 AM
#56
