07-24-2008, 03:52 PM
#41
Originally Posted by Bmorezcmunee
ugh, now i gotta buy that expensive royal purple...(7.50 a quart) and change my oil. oh well. there goes my beer money
nooooo......please don't do that.
your new oil is still going to pick up residual moisture. Change it with something less expensive, run if for a week, then do a flush/change with the expensive stuff.
07-24-2008, 03:53 PM
#42
well when i first used royal purple it unleashed a few horsies that were still in the stable with the old oil i was using. maybe it was all in my head but id reccommend it
::edit::
oh ok thanks BlackJack.
now i can drink!
#43
Ohhh ya he is verry right! change it with the cheap stuff
then royal purple
still wouldnt pay that much for oil
lets see
3000 mile change cost you
About 40 bucks
6000
75 bucks
12000
150 bucks
24000
300 bucks
48000
600 Bucks
96000
900 Bucks! Sweet Jesus! thats alot of moolah!
etc etc....
07-24-2008, 03:58 PM
#44
::edit::
now i can drink!
Yes, you are correct. Royal Purple does have better lubricating properties giving less friction. Though the HP gain by Royal Purple alone is negligible, it's still better if you can afford it. However, I use Mobil 1 (synthetic) in my turbo setup and have had no sludge buildup (inside the engine looked sparkly new) no "coking" in the turbo, and runs really good. It's still more expensive than standard motor oil, but it's not quite as expensive as RP.
07-24-2008, 04:07 PM
#45
then royal purple
lets see
About 40 bucks
6000
75 bucks
12000
150 bucks
24000
300 bucks
48000
600 Bucks
96000
etc etc....
yeah but with RP you wouldnt have to change every 3000. id say probably every 5000.
07-24-2008, 04:09 PM
#46
so just like some cheap stuff then. ill just get whatever oil change special they have at autozone this week. thanks everyone. pardon my n00br0sity earlier. i shall keep that to a minimum
07-24-2008, 04:10 PM
#47
i ALWAYS change after 3000
07-24-2008, 04:21 PM
#48
well RP is a full synthetic. thats why i say every 5000. when i used conventional i changed every 3000 too. if u get a good filter like a K&N or a Purolator, you can feel confident in doing that
07-24-2008, 04:41 PM
#49
...ok
07-24-2008, 05:56 PM
#50
on vacation
Originally Posted by [ion] C2
i've gone though such terrible weather for 6 hours straight with my CAI without any issues. you cannot suck up water unless you go through a puddle deep enough to cause the end of your tubing to be submerged in the water. and long enough to have it get to the engine.
not true.. i've slapped a puddle of water id say about 2 inches deep, mabey 5 foot by 2 foot in size.. doin around 30 mph- my intake sucked it up and the car stalled in the middle of the road.. that filter -does not- have to be submerged for it to suck up water and kill the engine
and about royal purple.. a car running royal purple (this coming from their website.. not me) can last 12,000 miles without an oil change.. not saying ID go that far.. but that's what it says.. go read up on it
WILL NEVER FORGET
07-24-2008, 06:13 PM
#51
that am true Midgear . i stalled at every red light thereafter. and im gonna buy some oil and a filter asap. then after a week or so ill throw that royal purple back in there
07-24-2008, 06:39 PM
#52
I would still get full synthetic cheap oil instead of any regular oil for a week. I heard regular and synthetic oils doesn't like each others very much, thats why I've been told to buy some engine cleaner before switching to synthetic.
I run Mobil 1 here.
07-24-2008, 07:16 PM
#53
I run Mobil 1 here.
That's why I said run cheap stuff and then do a drain/FLUSH when you change oil. You're absolutely right, regular and synthetic don't like each other, unless you enjoy having a block full of jello.
07-24-2008, 08:08 PM
#54
i effing love jello!!
07-24-2008, 08:17 PM
#55
on vacation
rofl! ^^
WILL NEVER FORGET
07-24-2008, 10:44 PM
#56
dont forget the pudding!
07-24-2008, 10:48 PM
#57
i thought mixing synthetic and conventional was a misconception because synthetic isnt actually a synthetic. but i will do as im told
07-24-2008, 10:58 PM
#58
on vacation
It Does What It's Told!
WILL NEVER FORGET
07-25-2008, 10:57 AM
#59
it puts the lotion on its skin!!
07-25-2008, 11:34 AM
#60
I said to hydrolock. You must've gotten something wet in there so it didn't fire or a sensor didn't work right and shut down. Water isn't compressible. If you suck up enough water so that the air can't be compressed much or there is no air in the cylinder at all, it will hydrolock; the piston can't compress the water so that force exerts back on the hardware and there goes your pistons/rods/stuff.
I've driven through the most unbelievable amount of rainfall and puddles and have never had an issue.
