Old 08-17-2008, 10:56 AM   #1
itsbmw
DTC Diagnostic Trouble Codes.
Arranged by:
DTC
then
Description
DTC B0016
RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
DTC B0017
RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open
DTC B0018
RF/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
DTC B0022
LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
DTC B0024
LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
DTC B0026
LF/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open
DTC B0051
Deployment Commanded
DTC B0053
Deployment Commanded with Loop Malfunctions Present
DTC B1000
BCM Malfunction
DTC B1001
Option Configuration Error
DTC B1365
Device Ignition 0 Circuit
DTC B1369
Ignition 0 Fault
DTC B1374
Ignition 1 Fault
DTC B1379
Ignition 3 Fault
DTC B1780
Theft Lock
DTC B2532
Front Foglamp Relay Out Short to Ground/Open
DTC B2533
Front Foglamp Relay Output Short to Bat
DTC B2558
Interior Lamp Control Output Short to Battery
DTC B2575
Headlamp Request/Feedback Mismatch
DTC B2577
Headlamp Control Circuit Low
DTC B2578
Headlamp Relay Output Short to Battery
DTC B2585
Parklamp Control Circuit Malfunction
DTC B2587
Parklamp Relay Output Short to Ground/Op
DTC B2588
Parklamp Relay Output Short to Battery
DTC B2600
DRL Error
DTC B2601
DRL Stuck
DTC B2602
DRL Relay Output Short to Ground/Open
DTC B2603
DRL Relay Output Short to Battery
DTC B2647
Ambient Light Sensor Circuit Low
DTC B2648
Ambient Light Sensor Circuit High
DTC B2752
Horn Relay Coil Circuit Low
DTC B2753
Horn Relay Coil Circuit High
DTC B2947
Security System Sensor Power CKT Low
DTC B2948
Security System Sensor Power CKT High
DTC B2957
Security System Sensor Data Circuit Low
DTC B2958
Security System Sensor Data Circuit High
DTC B2960
Sec Sys Sensor Data Incorrect but Valid
DTC B2965
Key In Ignition Fault
DTC B3031
Security System Controller in Learn Mode
DTC B3033
Security System Indicates Tamper
DTC B3127 or B3128
Driver Door Unlock Circuit
DTC B3132 or B3133
Door Unlock Circuit
DTC B3137 or B3138
All Door Lock Circuit
DTC B3267
Decklid Relay Output Short to Ground/Open
DTC B3268
Decklid Relay Output Short to Battery
DTC C1214
Solenoid Valve Relay Coil Contact Circuit Open
DTC C1217
Pump Motor Shorted to Ground
DTC C1218
Pump Motor Circuit Shorted to Voltage or Motor Ground Open
DTC C1221-C1235
Wheel Speed Sensor Circuit
DTC C1236
Low System Supply Voltage
DTC C1237
High System Supply Voltage
DTC C1241
Variable Effort Steering Malfunction
DTC C1242 or C1243
Pump Motor Circuit
DTC C1245
Low Tire Pressure Detected
DTC C1247
Low Brake Fluid Detected
DTC C1254
Abnormal Shutdown Detected
DTC C1255 or C1256
ECU Malfunction
DTC C1261-C1268
EBCM Internal Solenoid Circuit
DTC C1275
PCM Requested ETS to Be Disabled
DTC C1278
RF Solenoid Circuit Open or Shorted to Ground
DTC C1287
Steering Position Sensor Circuit
DTC C1295
Brake Lamp Switch Circuit Open
DTC C1298
PCM Indicated Class 2 Serial Data Link Malfunction
DTC P0030
HO2S Heater Control Circuit Sensor 1
DTC P0101
Mass Air Flow (MAF) Sensor Performance
DTC P0102
Mass Air Flow (MAF) Sensor Circuit Low Frequency
DTC P0103
Mass Air Flow (MAF) Sensor Circuit High Frequency
DTC P0105
Manifold Absolute Pressure (MAP) Sensor Performance/Range
DTC P0107
Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
DTC P0108
Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
DTC P0112
Intake Air Temperature (IAT) Sensor Circuit Low Voltage
DTC P0113
Intake Air Temperature (IAT) Sensor Circuit High Voltage
DTC P0117
Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
DTC P0118
Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
DTC P0121
Throttle Position (TP) Sensor Performance
DTC P0122
Throttle Position (TP) Sensor Circuit Low Voltage
DTC P0123
Throttle Position (TP) Sensor Circuit High Voltage
DTC P0125
Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
DTC P0128
Engine Coolant Temperature (ECT) Below Thermostat Regulating Temperature
DTC P0130
O2S Circuit Closed Loop (CL) Performance Sensor 1
DTC P0131
HO2S Circuit Low Voltage Sensor 1
DTC P0132
HO2S Circuit High Voltage Sensor 1
DTC P0133
HO2S Slow Response Sensor 1
DTC P0134
HO2S Circuit Insufficient Activity Sensor 1
DTC P0135
HO2S Heater Performance Sensor 1
DTC P0137
HO2S Circuit Low Voltage Sensor 2
DTC P0138
HO2S Circuit High Voltage Sensor 2
DTC P0140
HO2S Circuit Insufficient Activity Sensor 2
DTC P0141
HO2S Heater Performance Sensor 2
DTC P0171
Fuel Trim System Leak
DTC P0172
Fuel Trim System Rich
DTC P0201-P0204
Injector Control Circuit
DTC P0201-P0206
DTC P0218
Transmission Fluid Overtemperature
DTC P0230
Fuel Pump Relay Control Circuit
DTC P0300
Engine Misfire Detected
DTC P0301-P0304
DTC P0325
Knock Sensor (KS) Circui
DTC P0327
Knock Sensor (KS) Circuit
DTC P0336
Crankshaft Position (CKP) Sensor Performance
DTC P0340
CMP Sensor Circuit Low Input
DTC P0341
Camshaft Position (CMP) Sensor Performance
DTC P0401
Exhaust Gas Recirculation (EGR) Flow Insufficient
DTC P0403
Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
DTC P0404
Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0405
Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
DTC P0420
Catalyst System Low Efficiency
DTC P0440
Evaporative Emission (EVAP) System
DTC P0442
Evaporative Emission (EVAP) System Small Leak Detected
DTC P0443
Evaporative Emission (EVAP) Purge Solenoid Control Circuit
DTC P0446
Evaporative Emission (EVAP) Vent System Performance
DTC P0449
Evaporative Emission (EVAP) Vent Solenoid Control Circuit
DTC P0452
Fuel Tank Pressure Sensor Circuit Low Voltage
DTC P0453
Fuel Tank Pressure Sensor Circuit High Voltage
DTC P0461
Fuel Level Sensor Performance
DTC P0462
Fuel Level Sensor Circuit Low Voltage
DTC P0463
Fuel Level Sensor Circuit High Voltage
DTC P0480
Cooling Fan Relay 1 Control Circuit
DTC P0481
Cooling Fan Relay 2 Control Circuit
DTC P0502
Vehicle Speed Sensor (VSS) Circuit Low Input
DTC P0503
Vehicle Speed Sensor (VSS) Circuit Intermittent
DTC P0506
Idle Speed Low
DTC P0507
Idle Speed High
DTC P0530
Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit
DTC P0562
System Voltage Low
DTC P0563
System Voltage High
DTC P0601
Control Module Read Only Memory (ROM)
DTC P0601-P0607, P1600, P1621, P1627, P1680, P1681, or P1683
ECU Malfunction
DTC P0602
Control Module Not Programmed
DTC P0620
Generator Performance
DTC P0621
Generator L-Terminal Circuit
DTC P0622
Generator F-Terminal Circuit
DTC P0650
Malfunction Indicator Lamp (MIL) Control Circuit
DTC P0705
Transmission Range Switch Circuit
DTC P0711
TFT Sensor Circuit Range/Performance
DTC P0712
Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
DTC P0713
Transmission Fluid Temperature (TFT) Sensor Circuit High Input
DTC P0716
Input Speed Sensor Circuit Intermittent
DTC P0717
Input Speed Sensor Circuit Low Input
DTC P0719
Brake Switch Circuit Low Input
DTC P0724
Brake Switch Circuit High Input
DTC P0730
Incorrect Gear Ratio
DTC P0741
TCC System Stuck Off
DTC P0742
TCC System Stuck On
DTC P0748
Pressure Control Solenoid Circuit Electrical
DTC P0751
1-2 Shift Solenoid Valve Performance
DTC P0752
1-2 Shift Solenoid Valve Performance - No Second or Third Gear
DTC P0753
1-2 Shift Solenoid Circuit Electrical
DTC P0756
2-3 Shift Solenoid Valve Performance
DTC P0757
2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
DTC P0758
2-3 Shift Solenoid Circuit Electrical
DTC P1106
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
DTC P1107
Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
DTC P1111
Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
DTC P1112
Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
DTC P1114
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
DTC P1115
Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
DTC P1121
Old 08-17-2008, 10:57 AM   #2
itsbmw
Throttle Position (TP) Sensor Circuit Intermittent High Voltage
DTC P1122
Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
DTC P1133
HO2S Insufficient Switching Sensor 1
DTC P1134
HO2S Transition Time Ratio Sensor 1
DTC P1137
HO2S Circuit Low Voltage During Power Enrichment Sensor 2
DTC P1138
HO2S Circuit High Voltage During Decel Fuel Cutoff Sensor 2
DTC P1171
Fuel System Lean During Acceleration
DTC P1189
Engine Oil Pressure (EOP) Switch Circuit
DTC P1336
Crankshaft Position (CKP) System Variation Not Learned
DTC P1351
Ignition Coil Control Circuit High Voltage
DTC P1352
Ignition Bypass Circuit High Voltage
DTC P1361
Ignition Control (IC) Circuit Low Voltage
DTC P1362
Ignition Bypass Circuit Low Voltage
DTC P1374
Crankshaft Position (CKP) High to Low Resolution Frequency Correlation
DTC P1380
Misfire Detected - Rough Road Data Not Available
DTC P1381
Misfire Detected - No Communication with Brake Control Module
DTC P1404
Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P1441
Evaporative Emission (EVAP) System Flow During Non-Purge
DTC P1546
Air Conditioning (A/C) Clutch Relay Control Circuit
DTC P1554
Cruise Control Feedback Circuit
DTC P1585
Cruise Control Inhibit Output Circuit
DTC P1626
Theft Deterrent Fuel Enable Signal Lost
DTC P1630
Theft Deterrent Learn Mode Active
DTC P1631
Theft Deterrent Start Enable Signal Not Correct
DTC P1632
Theft Deterrent Fuel Disable Signal Received
DTC P1635
5 Volt Reference 1 Circuit
DTC P1639
5 Volt Reference 2 Circuit
DTC P1640
Control Module Output A Circuit
DTC P1650
Control Module Output B Circuit
DTC P1660
Control Module Output C Circuit
DTC P1670
Control Module Output D Circuit
DTC P1810
TFP Valve Position Switch Circuit
DTC P1811
Maximum Adapt and Long Shift
DTC P1860
TCC PWM Solenoid Circuit Electrical
DTC P1887
TCC Release Switch Circuit
DTC U1000 and U1255
Class 2 Communication Malfunction
DTC U1001-U1254
Loss of XXX Communications
DTC U1300
Class 2 Data Link Low
DTC U1301
Class 2 Data Link High
Sorry they wouldnt all fit on there.
EDIT: THese are for 2001. I don't know if they changed over the years or not.
I got these from a mechanic at the service dept at the dealership i work at.
and my scanner does scans to text so I put em on here for you
Old 08-17-2008, 12:48 PM   #3
You can also find these by typing "P0401" or the like into Google.
[ion] C2 is online now   Reply With Quote
Old 08-17-2008, 06:54 PM   #4
itsbmw
Hey i put them all in one post. They can type it in search here if they want. It's better than someone asking what the code is if they are too lazy to google..
Old 08-17-2008, 07:25 PM   #5
true i was just throwin that out there lol
at first i thought you were listing all the codes you have showing on your car, i was like "DTC B0051 - Deployment Commanded" that's not good
Old 08-17-2008, 09:05 PM   #6
itsbmw
Ahaha noooo . If I had all those codes I think my car would be in the junk yard by now.
Old 08-17-2008, 10:22 PM   #7
yea thats a good list to have so its comes up when people search. but i'm like ion i started reading and thought holy shit your car has problems
Old 08-17-2008, 10:27 PM   #8
Vinalero
Vinalero's Avatar
Thats like the second post of these in 2 weeks, aint it? lol
