08-21-2008, 06:30 PM
#21
When I give my car more Throttle than usual (just because I love the way it pulls ) I can smell gas right after for a short period of time. I presume that I must run rich at WOT (which I prefer than running lean). So if his car runs rich, it could smell in the car, no?
Besides, my first car which was a 1986 camaro used to always smell gas in the car. I found out that one O-ring from the manifold was loose and kept getting loose so I was tighting the screws once in a while. I ran a full summer with that car that way, that must have been bad for my brain for sure! lol
08-21-2008, 08:15 PM
#22
I only smell it with air blowing... and then that pos only works on high lol. but i have the blower resistor, i just havent switched it.
And honestly, it may smell like gas only like 3 times a week. I make it to work and by the time i leave for lunch i dont have any issues with it.
08-21-2008, 08:47 PM
#23
Originally Posted by Midgear
lol.. replacing an O ring is like taking a tiny ass rubber band and putting it around the tip of your finger- its easy as pie.
.....or like putting on a condom. Maybe pickup a hooker, see how it's done, then tackle the car the next day!
08-21-2008, 08:56 PM
#24
on vacation
^^ I was going to say that, but I figured id keep the conversation somewhat intelligent lol
WILL NEVER FORGET
08-21-2008, 09:50 PM
#25
hows your gas mileage? if your losing gas... that would be off a bunch.
08-22-2008, 12:37 PM
#26
gas mileage is not so great right now... but its actually in the shop right now so i should know soemthing in a lil bit. I will keep everyone posted
08-22-2008, 03:56 PM
#27
So i got my car back and they found no issues...
I know my friend and i arent crazy... they assured me i had no issues. But they did however pull codes PO440A & PO420A... does anyone know what those are?
08-22-2008, 06:25 PM
#28
Originally Posted by Redog
The smell of raw gas it a leak as will have to be fixed ASAP.
Don't know how fuel is delivered on the 2.4 though. I had a "O" ring go bad in the fuel reg on the 3400
So i took my car and had it checked... they found nothing wrong. But they did put in my blower resistor... now all speeds work lol... and i have not smelled gas since Tuesday
08-22-2008, 06:32 PM
#29
maybe look where your blower motor is... any chance there fuel lines running near that?
(i'm not sure where the motor is, and where the fuel lines are)
08-23-2008, 10:19 PM
#30
stay away from the huffin jimmy
smirking is important
follow the titans
08-29-2008, 10:40 AM
#31
I found the problem... it was the fuel pressure regulator... got teh part at autozone for $65 and installed for free... the guys at the shop felt bad bc they didnt catch it so no charge for labor
10-03-2008, 12:13 PM
#32
hey ndot how could you tell it was the regulator?...i have this problem right except i only smell it when my heat is on and i want to fix it before it gets to cold to work outside
00 alero
so far: jvc cd player, sony xplod speakers, jl 1000/1 amp
2 12" kicker cvr, wai, green underglow
coming soon: some led's, better subs
10-03-2008, 12:39 PM
#33
Most likely fuel was coming out of the vacuum port on the regulator.
10-03-2008, 12:47 PM
#34
When i would first crank it i popped the hood and could actually leaking oout of the regulator... it was dripping down onto other parts. U will see it if its the regulator
10-04-2008, 12:28 AM
#35
thanks...ill have to check that out tomorrow when i can see
00 alero
