Old 12-23-2008, 09:33 PM   #21
bdyman
look at the home page of this site
Old 12-23-2008, 09:33 PM   #22
Frostbite545
Frostbite545's Avatar
Frostbite545 is an unknown quantity at this point
Send a message via AIM to Frostbite545
Well my stuff is pretty much listed in my sig :P
Performance Mods:
Cold Air Intake by Doctor Speed
Digital Horsepower Tuned PCM
180 Degree Thermostat
General Exclaim Ultra High Performance Tires
2 1/2" Pacesetter Cat-back Exhaust
High Flow Catalytic Converter
S&S Ceramic Coated Headers
Exterior Mods:
...cut a hole for my second set of exhaust tips ?
Audio Mods:
Cassette adapter for my ipod touch. Oh yeah.
Interior Mods:
Mounted a Whistler Pro-78 Radar Detector on my dash :P
- (2000 GL) 14.748 @ 93.04
- Doctor Speed Cold Air Intake
- DHP PCM / 180* Tstat
- General Exclaim UHP Tires
- 2 1/2" Pacesetter Exhaust
- S&S Headers
Frostbite545 is offline   Reply With Quote
Old 12-23-2008, 11:09 PM   #23
darksobsession
darksobsession's Avatar
darksobsession is on a distinguished road
Send a message via AIM to darksobsession
Originally Posted by itsbmw View Post
Just bought a KCA-ip500. Dang I'm doing so much..
what's that?
sigs are annoying
darksobsession is offline   Reply With Quote
Old 12-24-2008, 10:59 AM   #24
mfuller
Oh boy....let me see....
Performance (Powertrain):
MP Racing Cold Air Intake
TCE Motorsports 65mm billet throttle body
TCE Motorsports phenolic plenum spacers
Wide Open Throttle Technologies Stage 2 ported upper intake manifold
Wide Open Throttle Technologies ported lower intake manifold
Wide Open Throttle Technologies street/strip ported cylinder heads (3500 valves and keepers, Comp Cams titanium retainers and 28986 valvesprings)
Heads blueprinted by LAM Engines
Sealed Power hyperutectic pistons (1mm oversize)
Speed-Pro piston rings
Block bored .040" over (1mm overbore)
ARP harmonic damper (crank) bolt
ARP flexplate bolts
ARP connecting rod bolts
Wide Open Throttle Technologies Stage 3 NA cam (1280 grind)
Sealed Power roller lifters
Sealed Power main and cam bearings
Clevite 77 rod bearings
Fel-Pro gaskets
Hypertech 180 degree thermostat
Delphi 28#/hr Multec 2 fuel injectors (flowmatched by WitchHunter Performance)
Balanced rotating assembly (LAM Engines)
Custom MPRacing PCM tune via DHP PowrTuner and HPTuners
3.42 final drive ratio (33/37 tooth drive/driven sprockets)
Raybestos Blue Plate Special clutches
Superior Transmission billet accumulator pistons
S&S headers(ceramic-coated by Bonehead Performance)
Metal 'Cat metallic substrate catalytic converter
SLP Performance 2.5" mandrel-bent exhaust
Magnaflow muffler and tips (woo hoo!!!)
Caspers Electronics cooling fan override
GReddy oil catch can
Brakes, Wheels/Tires and Suspension:
Baer Racing Track+ front brakes (13" 2-piece rotors, 2-piston calipers)
Braided stainless steel brake lines
KYB AGX adjustable struts
H&R Sport springs
The Next Level front swaybar (28.6mm)
The Next Level rear swaybar (22.2mm)
GM cast aluminum front lower control arms (polished) w/ poly bushings
Custom billet front endlinks with poly bushings
MRZ Performance front upper strut brace
SLP Performance rear upper strut brace
Kosei K1 Racing pressure-cast alloy wheels (custom-drilled for proper centerbore and BCD; 17x7.5", +35mm offset)
Bridgestone Potenza RE-01R tires (225/45R17)
Exterior and Appearance:
Razzi ground effects (front fashia, rear apron, side skirts)
Razzi decklid wing spoiler
Euro-spec headlamp modules (clear corners from the factory - woo hoo!!!)
4300K H1 HID low-beam headlamps
3000K 880 HID foglamps
Custom (I forget who did it) DRL defeat and manual headlamp controller
MRZ Performance polished brake fluid cap
MRZ Performance polished MAP sensor cover
MRZ Performance polished oil cap cover
MRZ Performance polished power steering fluid cap cover
MRZ Performance carbon fiber/polished strut tower covers
Interior:
Recaro Speed sport bucket seats
LoteK 3-gauge A-pillar pod
Aeroforce Interceptor scan gauge
Innovate Motorsports G3-series oil pressure gauge
Innovate Motorsports G3-series wideband O2 guage and controller
Other:
RSM Racing billet aluminum/polyurethane front transmission mount
Wide Open Throttle Technologies billet aluminum/polyurethane passenger-side upper motor mount
I think that's what I have installed for now....this list subject to change at any time.
Old 12-24-2008, 11:27 AM   #25
one stock after market fender
second hand gls rims
junk yard hazard switch
a switch in my center consol that controls nothing
Old 12-24-2008, 11:38 AM   #26
itsbmw
Old 12-24-2008, 11:47 AM   #27
rowdygls
rowdygls is an unknown quantity at this point
Send a message via AIM to rowdygls Send a message via MSN to rowdygls Send a message via Yahoo to rowdygls
Wide Open Throttle Technologies Stage 2 ported upper intake maifold
Wide Open Throttle Technologies street/strip ported cylinder heads (blueprinted with SI valves, Comp Cams springs and retainers)
Sealed Power hyperutectic pistons (1mm overbore)
Sealed Power main, rod, and cam bearings
Fel-Pro gaskets
Ishihara-Johnson Teflon crank scraper
Custom PCM tune via DHP PowrTuner
TOG headers (ceramic-coated)
H&R Sport springs
Kosei K1 Racing pressure-cast alloy wheels (17x7.5", +35mm offset)
Dunlop Direzza Sport Z1 Star Spec tires (225/45R17)
Exterior (Appearance):
Interior:
Lotec 2-gauge A-pillar pod
Innovate Motorsports wideband O2 guage and controller
This list kinda defeats your sig.
my cardomain: http://www.cardomain.com/ride/605233Alero
Chapter Member
rowdygls is offline   Reply With Quote
Old 12-24-2008, 12:15 PM   #28
01OldsAleroGt
01OldsAleroGt's Avatar
01OldsAleroGt is on a distinguished road
Send a message via AIM to 01OldsAleroGt Send a message via MSN to 01OldsAleroGt Send a message via Yahoo to 01OldsAleroGt
hey rowdy... sarcasm
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
01OldsAleroGt is offline   Reply With Quote
Old 12-24-2008, 01:22 PM   #29
rowdygls
No kidding...thanks captain obvious. I was just poking fun at Matt.
Chapter Member
Old 12-24-2008, 01:39 PM   #30
will176
will176's Avatar
will176 is on a distinguished road
performance-
custom fabbed (by me) intake
taylor spark plug wires
exterior-
custom grille ( broken due to an encounter with a snow bank)
interior-
alpine cda 9884 head unit
polk audio speakers
blue under dash neon
coming 2009 (hopefully)
new center exit exhaust
ported intake manifold
65mm throttle body
rims
corvette brake mod
lowering springs/ pfyc anti roll bars
adjustable struts (doubtfull)
2001 gls 3400 sfi
will176 is offline   Reply With Quote
Old 12-24-2008, 04:23 PM   #31
mfuller
I think your list is probably longer......
Where's your Recaro baby seat? Addison's probably still too small, eh?
Old 12-24-2008, 05:35 PM   #32
rowdygls
no, I think your list is definately longer. I have the parts, just not installed.
my cardomain is update for the most part...I think, but here is my contribution to this thread.
Performance:
Dr Speed CAI
62mm TB (wishing this was the billet version)
MP62 S/C w 2.8 pulley (2.2 pulley in garage waiting for supporting mods)
(P/P upper in garage)
(trailblazer injectors in garage)
(Milzy's stage 1 or 2 s/c cam in garage)
(necessary hardware for cam in garage)
180* T-stat
Custom tuned PCM
TOG ceramic coated headers
Magnaflow Metal Cat
SLP Catback exhaust and muffler(2.5" piping all the way)
Suspension:
Koni Yellow adjustable struts
Eibach lowering springs
F/R strut tower bars by SLP??
(F/R sway bars by speed built in garage)
19" Racing Hart C6 (OSV rims)
General Exclaim UHP tires
(working on the brakes is the next project)
Exterior:
Custom Blue Pearl paint job that mimics the OSV concept
Andy's Auto Sport kit
Modified cowl bonnet (holes cut in bottom and in the cowl to be functional)
Spoiler delete(new trunklid)
Silverstars for all forward facing bulbs
DRL over-ride as well
Interior:
Triple gauge pod w/ air/fuel, temp, and volt (looking to replace a few of those with an Interceptor gauge and then a boost gauge)
White gauge overlay
Pioneer something or another cd player
Phoenix Gold something or another amp
2 10" Infiniti something or another subs
the baby seat is coming(hopefully..haha)
Chapter Member
Old 12-24-2008, 08:36 PM   #33
mfuller
You forgot the swanky cowl bonnet.....
Old 12-24-2008, 11:01 PM   #34
rowdygls
fixed....thank you
Chapter Member
Old 12-24-2008, 11:22 PM   #35
My list is short and mostly listed in my sig anyways...
  • Engine Performance
  • Hybrid AEM / K&N cold-air intake
  • AEM bypass valve
  • Cat-Back exhaust from the IRL pace car Alero with a Corvette C6 exhaust tip.
  • Road Handling Performance
  • 17" polished 7-spoke wheels (same style as Final 500 Aurora)
  • Aurora Final 500 centercaps.
  • Continental ContiExtremeContact 235/45R17 tires.
  • 12" front dual piston brake upgrade (first one on a N-Body!)
  • Speedbuilt Front and Rear Stabilizer Bars
  • Interior
  • Delphi GMT257 TNR Navigation radio
  • Parrot CK3300 Bluetooth Hands-Free kit
  • Catch-All front floor mats
  • Exterior
  • HID Headlamp upgrade
I also have a Infinity Basslink II sub/amp that I just haven't wired up yet.. As well as some *new* aluminum control arms.
Old 12-24-2008, 11:39 PM   #36
KenshinZero
KenshinZero's Avatar
KenshinZero is an unknown quantity at this point
wai intake
super white headlamps
Falken tires
There is a hole behind the drivers ide seat somewhere, so that could count as a weight reduction, lol
1999, RED Alero GX
KenshinZero is offline   Reply With Quote
Old 01-07-2009, 04:24 PM   #37
kingOfAllCivics
kingOfAllCivics is on a distinguished road
CAI
hankook tires in the front
pcm on the way
as well as p/p upper and lower with 65mm tb
kingOfAllCivics is offline   Reply With Quote
Old 01-07-2009, 04:43 PM   #38
Alerosaint
Gone but not forgotten
Alerosaint's Avatar
Alerosaint is on a distinguished road
Send a message via AIM to Alerosaint Send a message via Yahoo to Alerosaint
its in the sig....well for the most part
Alerosaint is offline   Reply With Quote
Old 01-07-2009, 06:18 PM   #39
Silentalero
Kitteh is back!!!!
Silentalero's Avatar
Update on my car, I put some vinyl on the window..hells yea!
97 Nissan 240sx - sr20det
94 Nissan 240sx convertible
01 Suzuki gsxr 750
Old 01-07-2009, 06:41 PM   #40
mralternator.com HO alternator 160A
Cargodz lightweight overdrive pulley
Optima 75/35 redtop battery
PFYC dual gauge pod
Glowshift Electronic Oil pressure sensor
Glowshift Voltmeter
Optimus 400W 4 channel amp
Lanzar 1400W 4 channel amp
Soundstream XTS 6.9
Soundstream Tarantula 6.5 components
2x Fosgate HE2 10"
Pioneer P400-UB
Custom WAI
Custom Vent/Door lighting
Custom Gauge lighting
Custom 3rd Brake Light
Custom Dome Light
Grand Am Dual Post Mirrors
Stock 15" tires (summer)
15" Dunlop Graspic Tires (winter)
