Old 01-03-2009, 10:16 PM   #1
How To: Fix rear window defroster
I did it today, boy it feels good to have a rear window defroster after being broken for about 5 years. I just wanted to know how to do it before tearing into the job, plus I always thought it was the modular itself that was bad, but it's the plug that melts causing the defroster to not work
Tool for the job.
Breaker bar (3/8 drive)
10mm socket (1/4 drive)
1/4 drive socket
3/8 drive socket
t-50 socket (3/8 drive)
Thick pilers
small screwdriver
wire stripper and connecters for no soder
and for sodering
Sodering iron
Thinest electrical soder as possible
Remember some steps are for 2 door models only
1. (2 door model) Use a T-50 to remove the seat belt bolt, use a breaker bar if necessary, it will move
2. Use a small flathead screwdriver to pry out the plastic pin holding in the coat hook.
3. Fold down the rear seat.
4. Gently pull the trim piece away from the body. Work around the edges.
5. (2 door model???) Pull out this small panel. This prevented me from pulling the panel completely off the body. This has the hinge bar going thru for the fold down seats. Just pull and leave hang
6. Now you can see the mod on the "C" pillar
7. Unplug the window connectors
8. Unplug the main plug from the mod. I pulled mine thru the seat belt area.
9. Use a 1/4 drive socket and a 10mm socket to remove the bolt from the body
10. Pull the mod down and out from the seat belt area, and unplug the radio antenna
11. Now both plugs are free
12. As you can see in step 8, the plug is melted away.Now you can cut the plug off and go to Step 13, or you can do this for sodering. Get the small screwdriver you used to remove the coat hook in step 2, and jam into the sides of the remaining plug. If it's melted away, it should be easy to break.
13. To finish the job, a nice beefy pair of plyers to crack the casing off
14. Remove the plug from the wires. You are not reusing the plug so it doesn't matter if you break it, just don't break the connecters inside it.
15. Open the mod around the egdes with the same small screwdriver. I bought another at the junkyard beforehand becuase I though the mod was the problem
16. Take off both sides until you see the board. Don't lose the rubber piece for the window plugs. Be sure to put it back in later
17. You can soder the the termials. The black wire goes on the right side, and the green goes on the left.
18. Be sure to remove as much of the plug from the black wire as possible. Use a small screwdriver, or wire brush to do the job, take care to not damage the plug.
19. While working, you can use the seat back hook to hold up the mod. Just put the wires in the hook
20. I wasn't happy with the sodering, so I cut the plugs off as close as I could, stripped the wires, and put connecters on them. I took care to put the connecters on in such a way that if they disconnected, they wouldn't touch the other side. I also put a small piece of electrical tape around the green wire's connceter.
21. Put everything back in reverse order. Be sure the wires don't come unpluged while putting it back. You can use electrical tape to tape the body of the mod closed, or to tape to the body of the car. Be sure the bolt is tight and the hook is back in the hole. I believe this is grounded here.
It works in my car now, going to keep an eye on it and make sure it's OK!!
After the job is done, band-aids and Neosporin
Old 01-03-2009, 11:09 PM   #2
Midgear
on vacation
ah ha! so its the plug that melts!
i've been trying to figure out what the hell is wrong with mine-
WILL NEVER FORGET
Old 01-04-2009, 07:48 AM   #3
Oldsman
Owner
Oldsman's Avatar
thanks a ton, Ken. this winter I will have to pull mine apart to see is same things is wrong with mine.
Beware of the BackStabber
Old 01-04-2009, 08:51 AM   #4
Vic28
Vic28's Avatar
Vic28 is an unknown quantity at this point
Send a message via MSN to Vic28
Pretty nice How To. I had to replace mine also once I got the car few months back. Atleast you were lucky that it was the only plug, mine melted on both places. So for those that have a problem, check first
Vic28 is offline   Reply With Quote
Old 01-04-2009, 08:55 AM   #5
Wow, ken did a how to!! AND has mostly non blurry pics for small pieces. I'm impressed. Good job,thanks for the addition.
Btw, it's solder not soder. I at the cold heat though... I hate those things, but good to know some people use them
Old 01-04-2009, 12:58 PM   #6
Vinalero
Vinalero's Avatar
Yeah, I changed mine about one year ago, But I didnt have a T-50, so I just pried the trim and went under it without really seeing anything, fun stuff.
Mine was also melted in both places, had to change them both.
I will probly run into the same problem again, because I just put a new connector in.
Old 01-04-2009, 02:10 PM   #7
I have a few How To's.
Yeah teh cold heat didn't do a very good job Glad I just borrowed it
Old 01-04-2009, 08:49 PM   #8
they(coldheat) are good for joining two wires... and thats it.
and they eat batteries quicker then digital cameras....
Old 01-04-2009, 11:31 PM   #9
I just didn't want to use a real soldering iron in the car. Might burn the carpet
Old 01-04-2009, 11:50 PM   #10
99alerogirl
Female.
99alerogirl's Avatar
99alerogirl will become famous soon enough
Wow nice, I'm gonna have to check mine out... It hasn't worked since I got the car
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
99alerogirl is offline   Reply With Quote
Old 01-05-2009, 02:18 PM   #11
black
Thread Crapper
black's Avatar
black is on a distinguished road
great job!!!!
Originally Posted by Ttop191 View Post
black is offline   Reply With Quote
Old 01-05-2009, 04:17 PM   #12
*UPDATE*
Tried it last night, not too much fog on the windows, but it clearing it up in about 2 mintues. Didn't smell any burning, however I'm still keeping an eye out, or should I say nose
Old 01-05-2009, 10:41 PM   #13
i could just imagine linda freaking out as you crawl outta the driver's seat to go take a look at it... while on a busy highway....
Old 01-05-2009, 11:41 PM   #14
Meh, she doesn't like riding in the Alero, but that would be funny though
Old 04-12-2009, 11:07 AM   #15
sorry about reviving an old thread,
can you just buy the new connectors? do we have a part #?
i dont want to solder.... i know mine has not worked in years...
Old 04-12-2009, 11:11 AM   #16
if you can solder it together... why bother buying the parts? solder is like... 1.69 for a big tube of it. it would take... maybe... 5 minutes.
Old 04-12-2009, 11:14 AM   #17
then have a mini electrical storm behind my seat!!!! what if im doing something!?!?!?!?!
Old 04-12-2009, 12:00 PM   #18
electrical storm? your soldering 2 wires and then just putting a little tape between them to prevent them from touching.
done.
Old 09-06-2010, 08:56 PM   #19
mrmike
mrmike's Avatar
mrmike is an unknown quantity at this point
mine got really burnt. it melted the plastic casing and there was melted solder in the bottom of the case as well. Should I try to hook it up to see if it works or should i just get a new one?
mrmike is offline   Reply With Quote
Old 09-06-2010, 10:44 PM   #20
If you can get the melted plastic off the prongs and wires, I say solder
