03-08-2009, 09:41 PM
#101
Hmmmm, not sure about the EGR, but looks like you got the EGR with that motor, so as ling as the wires connect up right you might be OK.
03-08-2009, 09:43 PM
#102
Female.
yeah, i heard something about how they're mounted horizontally on 99's and vertically after that, but they should work either way.
2012 Hyundai Veloster - new 40 MPG DD!!
1990 Nissan 300ZX Twin Turbo 5 speed - "Zeus"
2005 Nissan Titan SE King Cab 4x4 - gas guzzler
03-08-2009, 09:50 PM
#103
As long as the EGR on that motor you got still works, you might as well use it. Looks like you got a few other sensors as well, the MAP sensor is there, all the injectors, probably the knock sensor and the collant temp sensor on the thermostat housing. You're set.
03-08-2009, 11:13 PM
#104
if you are doing a build just delete the EGR, it's not worth keeping around....
03-08-2009, 11:59 PM
#105
Female.
yeah, and we don't have emissions anyways. does deleting it have any benefit?
03-09-2009, 12:48 AM
#106
Any chance you'll wind up with a spare power steering pump? If so, I could really use it. Mine doesn't like me anymore. Sounds like my ex-wife, always whining!!
03-09-2009, 07:22 AM
#107
Check out my thread for my LIMG project. I've got pictures of the UIM and the throttle body right after I took them off. The insides are black as tar. That's from the EGR. Exhaust Gas Recirculation. The valve lets exhaust gasses back in through the intake, causing carbon build-up on everything it touches. Dumb invention...
03-09-2009, 07:51 AM
#108
Female.
haha I needed the power steering pump too, but no I didn't get it
03-09-2009, 08:11 AM
#109
You had some worried leg humpers in here! They thought the guy may have taken you! Now you have something to do every day.
03-09-2009, 11:05 AM
#110
Female.
haha no I had my stepdad and sister with me, so I had backup
03-09-2009, 03:47 PM
#111
Originally Posted by mfuller
The motor is not that big; you can fit it inside the Trailblazer just fine.
Is is a bit heavy though, especially considering the cast-iron block. About 400lbs. fully dressed.
You'll need some wood blocks to sit it on, and obviously a tarp or something so you don't leak any oil/other fluids and run the Trailblazer. I'd highly suggest an engine stand if you are planning on disassembling the motor.
This gives you an idea of the size (the accessories are missing, of course - alternator, power steering pump, AC compressor, and a few idler pulleys):
And here's an old one just sitting on a couple of wood blocks on the garage floor:
Lifting the entire engine assembly with those weak ass 10 mm middle intake bolts threaded into aluminum seems like a horrible idea.
03-09-2009, 11:20 PM
#112
Female.
i got bored and started disassembling today, even though it was still outside on the trailer! ha, i got impatient. anyways, i took off the TB, UIM, some random hoses and lines, the thermostat housing, the thermostat, and started taking off the LIM. this engine is DIRTY. i have pictures, but i'm far too lazy to mess with it all right now. i broke a socket adapter though and cut open my thumb, but hey, it was fun!
03-10-2009, 02:37 AM
#113
Will you marry me???
03-10-2009, 07:28 AM
#114
Nice, make sure you keep everything you take off. The easy part is taking it apart, the hard part is putting it all back together!
03-10-2009, 07:55 AM
#115
NEVER lift the engine by anything except the two large black steel lifting brackets!!! One is bolted to the front cylinder head and the other is sandwiched between the timing cover and the alternator.
I did not lift it by the LIM bolts......I'm not quite that clueless.
03-10-2009, 11:19 AM
#116
