04-04-2009, 02:12 PM
#41
Originally Posted by clutch1
Basement?.. Are you prepared for the house to reek?
yes.
we're always doing some kind of project in here. i COULD use the garage.. but we have 2 cars in there... and its still attached to the house. so its going to reek either way.
04-09-2009, 12:55 PM
#42
Hooray for speaker pods!
im going to do these now!
05-14-2009, 12:25 PM
#43
1) decent, just need to fix the bolt holes (after they glasses into place, they tipped a little. drill the holes out and it'll be fine.
2) doh... someone didn't draw his line right. Gotta reglass the end of this one... Gimme a break.. i'm new to this. Whats the best way to fix this? put the dried glass in there, tape off the missed section, and glass it onto the existing?
does it matter if the base is really wavy? I'm going to vinyl over these, so i'm assuming that'll even the base right out.
I also know i still have more sanding/evening to do. they are rather "angled" in some spots.
...and my thickness is horrible. some spots are really thick, then others are kinda thin... i'm definitely not a pro at this.
05-14-2009, 12:39 PM
#44
i dont know how thats going to look with FG just bolted to the stock vinyl panel should have FGed the whole thing if you have so much time
05-14-2009, 12:43 PM
#45
Its a PITA man.
Heres mine:
We both did this WRONG though. Im going to rebuild mine. Take a look at this pic:
We need to cut away some off the door panel to allow the fiberglass to sink in more. Also pull the speaker back, slightly. To allow room for the glove box...
05-14-2009, 01:57 PM
#46
so how do they attach? confused!
05-14-2009, 02:03 PM
#47
who said i'm remotely close to done? i still have to make the speaker baffle, get that angled, cover the whole thing in fleece, then glass over that, THEN cover all that in vinyl. You'll never see those bolts, unless you look from the inside...
the bolts go through the holes in the door, then attach a washer and nut to each on the inside. mounts it quite securely.
05-14-2009, 02:16 PM
#48
Ok so like Ryans pic then you must be mounting it to the door panel before you are putting the panel back on the door?
05-14-2009, 02:18 PM
#49
indeed, that IS how i'm mounting it.
05-14-2009, 02:39 PM
#50
im not retarded i was just saying my opinion, ive done a lot more FG work then you lol
05-14-2009, 02:43 PM
#51
I'd like to do a full FG door.. but i think its a little outta my skill set. I think after these, i'm retiring from FG.
05-14-2009, 02:45 PM
#52
Sorry...can't do that til I get my set.LOL
05-14-2009, 02:49 PM
#53
I'd have to finish these before i'd even remotely consider doing anymore. and even then... its too much damn work... it might take me the rest of the month to finish these... (and i'm not in school right now)
if i was, no freak'n way i'd do it.
05-14-2009, 03:16 PM
#54
Geterdone!
05-14-2009, 05:12 PM
#55
Look good, I'd fix the one just like how you said. Nice idea on securing them, that's exactly how I did mine
Should look nice when your done.
05-14-2009, 05:24 PM
#56
now that i know where the mount is going to sit (roughly) and how... i'm more then happy to cut some of that inner (useless) plastic out, so i have more speaker room... and can avoid hitting the glovebox.
05-14-2009, 05:41 PM
#57
The thing is, you will have to cut away some of your current glass and reglass a recess into it.
I cut a hole in mine...
Im not even going to bother with it. How it looks now = into the trash and try again. lol
05-14-2009, 05:43 PM
#58
...i think your wrong. and will fight tooth and nail to prove that.
05-14-2009, 07:01 PM
#59
Well... If youre not going to cut any fiberglass away to rework it why cut the surface under the glass?
05-14-2009, 07:13 PM
#60
clearly.. i have to cut a hole in the center to accomodate the back of the speaker/magnet...
