04-03-2009, 10:18 PM
#21
cobalts are ecotec
04-03-2009, 10:33 PM
#22
The Aleromod PITA
i know thats why i wonder if itll work, my girlfriend had one b4 she got her liscense, yeah her parents bought a car just for her to learn in, 05 cobalt, pwr lock but manual windows(weird) but it was fast as hell, i felt it was the transmission witch shifted quicker and better,
i always wondered if a trans swap would work
and would it be effective and worth it since i'm assuming you would loose the enhanced traction system
04-03-2009, 10:42 PM
#23
yea the ls cobalts have L61s i looked into doin this a few months ago when i found the tranny, but i heard finding the console pieces are a PITA though
04-03-2009, 11:03 PM
#24
The Aleromod PITA
PITA?, what console peices would be needed, would harnesses still match up and would you lose ets
04-03-2009, 11:07 PM
#25
NOT to mention clutch heres the console piece,
04-03-2009, 11:19 PM
#26
The Aleromod PITA
i was thinking an automatic one
04-04-2009, 07:47 AM
#27
i'm pretty sure auto for auto is going to be a retarded swap.
the shift points are controlled via computer, you can tweak that with HPtuners, or a PCM upgrade. the prior is recommended, though.
04-04-2009, 09:18 AM
#28
Wait a cobalt auto for an alero auto? Wats the point?
04-04-2009, 08:55 PM
#29
The Aleromod PITA
the auto from the cobalt felt like it shifted quicker and was faster, plus maybe i thought was were the efficiency difference was, was just a idea i had floating in my head, had kinda disregarded it but this thread brought it back to my mindseye
04-04-2009, 08:57 PM
#30
The Aleromod PITA
if its not tranny that makes the difference its either improvements on the ecotec or the weight/size of the cobalt, if its the motor r the improvements replicable on teh alero's with in a cost justified budget
04-05-2009, 01:06 AM
#31
If it felt like it shifted faster, it could be as simple as GM setting the computer so that the pressure in the transmission lines is higher on the cobalt than in the alero.
04-05-2009, 01:42 AM
#32
Boost Guru
Originally Posted by AleroRacing
my girlfriend had one b4 she got her liscense... 05 cobalt... it was fast as hell
I'm assuming you've never been in an actual fast car before?
04-05-2009, 02:08 AM
#33
Canada's Ghost
I support the idea of swapping an engine because it's cheaper, I don't think I would be satisfied with doing that I would love to have boost but after seeing what my cousins old civic could do I think I would want to run more boost so I would just build my engine with all forged internals and spend the money on a brand new turbo set up instead of used parts that don't have warranties on them.
04-05-2009, 03:30 AM
#34
No doubt!
Any time I drive another car after the STS, it's always like "Are we there yet?"
04-05-2009, 06:03 PM
#35
Originally Posted by AbHeLlRaZoR
I support the idea of swapping an engine because it's cheaper, I don't think I would be satisfied with doing that I would love to have boost but after seeing what my cousins old civic could do I think I would want to run more boost so I would just build my engine...
i agree this was just an idea but i think imma just get a t3 theres some manifolds on ebay for like 200 and i can probably get a used t3 for under 500
04-05-2009, 11:14 PM
#36
The Aleromod PITA
fastest thing would probably be a 89 thunderbird which my father said hes going to give to me, itll never happen
04-05-2009, 11:20 PM
#37
Is it a SC?
04-05-2009, 11:28 PM
#38
Canada's Ghost
not bad price wise I'm sketched out on used stuff but I think the easiest way would to be start out with a turbo set up on low boost for like a summer and save up and order parts for a full engine build to do over the winter.
04-06-2009, 06:07 AM
#39
Boost Guru
I'm sorry to hear that...
04-06-2009, 11:51 AM
#40
The Aleromod PITA
has the 302 and digital guages
