04-27-2009, 09:46 PM
#41
i got a red. ended up getting it for 99.99 new. booya!
found out what might have caused the problem. My 2ga alternator wire... apparently... was resting against my exhaust shield. after i connected my new battery, i kept seeing little flashes. i pulled the wire out... low and behold... there was a melted section of the wire. i patched it up (water tight for now, till i get a replacement) and rerouted the wire. New batt is in, not started yet. gotta reconnect my amp fuses and see how things go.
04-27-2009, 09:47 PM
#42
my alero runs with the - and + off, your alt died LOL
04-27-2009, 10:12 PM
#43
my alt died? rriggghhttt. you mean the one that puts out a constant 14.8V when running.
04-27-2009, 10:39 PM
#44
lol owned!
04-27-2009, 11:21 PM
#45
actually i have seen that happen before, i have no idea exactely why though. But one of the times i saw it happen is when me and a bud were boosting the hell out of a old car sittin in the trees to get it running. started smokin pretty nicely too.
04-27-2009, 11:49 PM
#46
The Aleromod PITA
where?
04-27-2009, 11:52 PM
#47
autozone. had some stuff i had to return from my LIM, and my bro's discount.
04-27-2009, 11:55 PM
#48
The Aleromod PITA
so jealouse, i used 40 dollars reward to cover the tranmission service
04-29-2009, 11:56 AM
#49
the terminal completely detached. alt had no way of giving power to the rest of the car.
...better yet... w/ the + terminal off, the ground circuit couldn't be completed... so.. no power.
you are mistaken, sir.
04-29-2009, 12:26 PM
#50
The car will run with the terminals disconnected, BUT you do have the potential for a voltage spike. AND if there's some large instant draw at low RPM (like a cooling fan coming on) it usually can't make up for it by the time it's too late and the engine will die.
04-29-2009, 12:40 PM
#51
i realized after i posted, that the way its wired... it would still work.
and mine didn't, because my alt wire was touching my exhaust shield.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
