Old 05-29-2009, 09:21 PM   #1
dhurst765
dhurst765's Avatar
dhurst765 is on a distinguished road
Question coolant drain plug
i was needing to know where the coolant drain plug is on the ecotec
dhurst765 is offline   Reply With Quote
Old 05-29-2009, 09:42 PM   #2
Valley olds
Valley olds's Avatar
I dont know, have you checked under the radiator? That's where Ive seen it on other cars.
Smoked tails- Cleared corners-RF P1 Subs- RF 201S Amp- Memphis Audio 4x6's and 6x9's-JVC Arsenal KD-APD89 Head Unit-front and rear z-spec strut tower brace- KYB GR2 struts- Intrax Springs- Magnaflow Muffler
Old 05-29-2009, 09:43 PM   #3
Not Your Average Alero.
Nate's Alero will become famous soon enough
Send a message via AIM to Nate's Alero Send a message via Yahoo to Nate's Alero Send a message via Skype™ to Nate's Alero
all alero's are on the driver's side, its either a green or white plug
Originally Posted by Chris2000 View Post
same like with oil you can check the level whether or not the car is on.
Old 05-29-2009, 09:50 PM   #4
247,000 mi
[ion] C2's Avatar
Little white plastic plug with an allen hole on the driver's side lower end of the radiator.
You put the allen wrench in, turn counterclockwise about 90 degrees, and pull the plug outward toward the front of the vehicle, and then coolant will drain from the bottom of the radiator out a hole underneath the white plug.
I just did this today.
Modifications | Aleromod.com Upgrades
Old 05-29-2009, 10:08 PM   #5
or he could have the wingnut
Old 06-03-2009, 02:16 AM   #6
There's also a drain plug for the engine block too.. I think it's back by the water pump.
Old 06-06-2009, 05:34 PM   #7
FrankNY
FrankNY's Avatar
FrankNY is an unknown quantity at this point
Send a message via AIM to FrankNY
This may help...............
http://www.aleromod.com/forums/showt...r+drain+pl ug
FRANK
2001 Alero GL
FrankNY is offline   Reply With Quote
Old 08-27-2011, 04:16 PM   #8
Goodman
Goodman's Avatar
Goodman is on a distinguished road
First Sorry! for this old thread but used the search button & saw this thread...
Got the exact same plug & i am using a wrench + extension & turn the valve 1/4 tun (counterclockwise) than tried to pull the plug but it doesn't move even tried with plyers so i am stock can't drain the radiator
I don't want to pull out the lower hose because that is messy & 90% of the time you'll have to replace the hose because it will leak even with a new clips hose...
Anyhow any tips for the valve plug?
Thx!
Goodman is offline   Reply With Quote
Old 08-27-2011, 06:15 PM   #9
mastershake
mastershake's Avatar
mastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond repute
you have to turn the plug just right so this little metal peice can slide out. you should be able to see it when you turn it correctly. then you have to like wiggle the plug while you pull and it should come right out.
mastershake is offline   Reply With Quote
Old 04-06-2012, 12:15 PM   #10
spc2125
spc2125's Avatar
im about to hit 150k and thats the recommended time to flush ur coolant
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
Old 04-06-2012, 12:35 PM   #11
yet another summer project...i think part of the reason that my temp keeps going above half even in fairly low temperatures is that the hoses need replaced...i also need a new serpentine belt because mine is cracking, i am not looking forward to undoing the motor mount in order to change a belt though
Old 04-06-2012, 12:57 PM   #12
spc2125
spc2125's Avatar
I know this isnt the coolant line, but i was wondering what it was?
(the black top closest to the hood, below yellow oil dipstick)
just call me "Doc"
Check out my alero!
Old 04-06-2012, 01:21 PM   #13
that is the a/c line and there is a fitting under the black cap to refill the a/c. i forget the proper name for it.
2005 Subaru legacy 2.5i 165k
Old 04-06-2012, 01:28 PM   #14
spc2125
spc2125's Avatar
does anybody want to take a picture of where the coolant plug is?
just call me "Doc"
Check out my alero!
Old 04-06-2012, 01:32 PM   #15
that black cap one is the high pressure line the one used to fill it is by the fire wall with a blue cap
2001 ALERO GL SED 4 DR--Build Date: 08-16-2000..Kanuck springs--awesome junkyard rims
There are 17 2001 ALERO GL 4 DR vehicles (0.019%) matching my exact options list.
Old 04-06-2012, 01:36 PM   #16
this is something similar to what i used at college to recharge the ac and discharge the old r-12 refridgerate.
the drain plug is on the bottom of the radiator.
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
