06-11-2009, 04:05 PM
#21
thats what I meant when I asked if you drive like an ahoe
06-11-2009, 04:16 PM
#22
lol not really like an ahoe but not like a grandma either
06-11-2009, 04:24 PM
#23
Well, 20 in the city isn't bad, I've gotten as low as 17-18 when I drove like an ahoe, but you should always get at least 30 on the highway with an eco. I'd get that overheating thing checked out, its likely your problem.
06-11-2009, 04:34 PM
#24
i have thought it might be my thermostat or coolant fan sensor
06-16-2009, 08:14 PM
#25
The Aleromod PITA
hey i went with the oem tire size 225 50 16 when i got my new rims but could the extra airflow of the new rims vs the hubcaps create extra drag and lower my gas mileage, i drive the car even slower then i did b4 now
my mod are rims and tires, cosmo intake, and eibach springs, i did all this at once and have gone from 27-29mpg to 25-26.5 mpgs
06-16-2009, 08:33 PM
#26
LMAO i like how you talk about the "extra airflow", have you actually measure it?? I think is more due to weight, than that so called drag.
06-16-2009, 08:40 PM
#27
The Aleromod PITA
ok airflow is a goofy reason, but whats bogging down my mileage, why didnt it go up with the cosmo???
06-16-2009, 08:44 PM
#28
What?
06-16-2009, 09:05 PM
#29
The Aleromod PITA
why has my gasmileage decreased instead of increased
07-06-2009, 02:23 AM
#30
got bigger wheels? shift kit?
sigs are annoying
07-06-2009, 02:46 PM
#31
Just wanted to ask since overheating was brought up... my fans dont kick on without the A/C being on... anyone know why? It gets up to the 3/4 mark and still no fans. so i just turn on the ac and it drops back down below the half mark.
07-06-2009, 03:50 PM
#32
ndottaylor:Just wanted to ask since overheating was brought up... my fans dont kick on without the A/C being on... anyone know why? It gets up to the 3/4 mark and still no fans. so i just turn on the ac and it drops back down below the half mark.
I think the fans are activated with the AC. Mine does that too.
07-07-2009, 12:41 PM
#33
that just sounds like a disaster waiting to happen
01-08-2010, 04:20 PM
#34
Sounds like a GM thing, my cavalier does the same thing, as does the camaro. The factory fan activation is set really high for some reason, but when the A/C is turned on, the PCM automatically turns the fans on.
Wow, just looked at the date of the last post, talk about resurrection.
Reason: Additional information
01-08-2010, 05:08 PM
#35
Yeah it's an older thread but a good one. My gas mileage on my 2.2 auto is about 20 city 27 hwy.
One thing not mentioned here is the differential gearing. I believe mine is 4.10. Does anyone have the rpo codes for the gear ratio. I also have the stock steelies. Not sure how big the tire is, but it's the stock size too.
01-08-2010, 06:22 PM
#36
Mine does this as well, but the A/C doesn't have to be on, it's just whenever I turn the fan up past like the 2nd or 3rd setting that the fans underneath the hood kick on.
01-08-2010, 06:24 PM
#37
my fasn do this as well, with the a/c on, they are both running... but it'll go to 3/4 and even higher...no fans...
PCM issue?
might just go SPAL fans, with Dual 12" fans, and a SPAL PWM
01-14-2010, 12:46 PM
#38
The Aleromod PITA
I dunno I average 29 mpg on the interstate and the gps rates that at an average speed of 78mph, with a high of 93, i run hard and do fairly well
01-14-2010, 01:24 PM
#39
So ppl think is not normal to have the Fans ON while the A/C???
01-14-2010, 03:17 PM
#40
78 average speed and high of 93 wth is the speed limit there I thought speed limit is 70 there.
Originally Posted by adam337
Goal - Mid 11s all motor.
