08-05-2009, 07:10 PM
#41
ill take pics of mine friday
08-06-2009, 12:11 AM
#42
holy eff for real? if you cant figure stuff like this out you shouldnt even be opening your hood
08-06-2009, 12:14 AM
#43
just eyeball it ... not hard.. modding cars is supposed to be custom. so for this type of thing it doesnt neccessarily have to be exact lol
08-07-2009, 02:27 PM
#44
The Aleromod PITA
its friday, how is the very top of the factory mess attached inside the fender, it felt like a bolt abhellrazor says its a plug so like do i need to drill out the bolt i broke to take it out or feel for a plug
08-07-2009, 02:53 PM
#45
dude...
1. pop the 3 tabs off the side of the fender well plastic
2. take off the bolt for the plastic guards connection to the top plastic peice(right next to the last pushpin you pop out) 10mm bolt i believe
3. remove headlight if desired to have more light/arm room
4. remove all stock plastic air box piping, and the air box itself , 10mm bolts again i believe maybe bigger.
5. make sure all stock stuff is gone.
6. if running all the way from the throttle body remove the stock ruffled looking tube with the sensors (at least on the v6) add your coupler re hook the sensors.
7. eyeball and measure the route you wanna take to the fender well (filter sits right behind the plastic you have pulled back so its hidden when you put the pushpins and bolt back on.
8. get cone filter, install with clamp to the end of the tubing
9. let plastic fender guard cover fall back to place, re push in the push clips to the holes and bolt the 10mm bolt to connect the two pieces again
10. put headlight back in (if took off)
11. stand back and admire your handy work
if this doesnt help GTFO lol
08-07-2009, 02:58 PM
#46
Canada's Ghost
Originally Posted by worknprog.99
dude...
so easy if you can't do it you should stop modding your car.
08-07-2009, 02:59 PM
#47
^^exactly... i cant believe i spent the time to write that up lol... but then again im at work lol
08-16-2009, 06:32 AM
#49
intake looks good. what's the deal with your battery?
sigs are annoying
08-16-2009, 01:30 PM
#50
The Aleromod PITA
ok thanks i just gotta get some extra cash to get the pipes, no job + dating new girls= broke, but thanks this mod will get done though
08-16-2009, 03:35 PM
#51
It is now in the trunk
08-16-2009, 07:54 PM
#52
I hope this girl's car has a longer hood for ya
You know kiddo, I really think you should STOP MODDING THE CAR!! A thread that 3 pages long for a simple insert slot "A" into slot "B" is just crazyness.
I could see asking the questions and this turning into a 2 page thread after a Thread Jesus brings it back after 3 years, but you just don't get it
