08-14-2009, 11:26 AM
#21
Thanks!
2K 3.4L 4DR GLS
12-13-2009, 07:18 PM
#22
I just bought an 01 alero last month and it came with the hazzard switch pushed in the dash as well. It still functions fine.. just gotta stick your finger in there and push it. Anyway, How the hell does that happen? You would have to push really hard to break it wouldnt you? Now that I read this I guess its common. Can anyone give me some tips on getting to it? Someone mentioned they would do a write up on it a few posts back. You get to it by removing the center vent right? How do I go about that? Pry around the edges until it pops out?
04-26-2010, 05:00 PM
#23
Gonna have to say thank you as well, this has been driving me crazy cause I don't crank my stereo, not exactly the tempo count I was looking for in music
Oh, and I now win the argument with my girl about where the noise was coming from... BURN !! Haha
Cheers !!
Reason: Double Play... FTW
04-26-2010, 05:39 PM
#24
airrazor, thanks for the bump. Mine just started doing this... i didn't even know we had a fix already for it.
+1 thread zombie. It helped this time!
04-26-2010, 05:43 PM
#25
Ya couple years after I had the turn signals replaced it started doing that. I let it go even though it drove me mad and it just went away one day. Never looked at it.
MP Racing CAI, Pacesetter Exhaust, and PCM. High flow CAT. KYB GR2 struts. Canuck Motorsport Springs. Cross drilled rotors. Stern ST18 17" rims.
07-14-2011, 02:56 AM
#26
Originally Posted by bkathsalero
ATMOSPHERE: If it pushes into the dash remove the center vent, remove the hazard switch and replace the bracket that holds the hazard, I'll make a how to later as I have to do one on a gold alero at work today, had to wait a day for parts
ok heres a little info to start off
the bracket the hazard switch sits in is gm part # 22627609
The hazard switch itself is gm part # 10359040
OR, if you just can't wait........
Drill a hole right Thar
Then loop the appropriate sized cable tie thru it and around the harness plug behind the H-switch, and tighten securely. But before doing that, take your favorite contact cleaner and spray that sucker:
Then never use it again
10-03-2017, 05:55 PM
#27
Gotta replace the hazard switch, what's the trick to removing the center vent?
10-03-2017, 06:29 PM
#28
I actually cracked mine getting it out. I even removed the radio and the clips were still a pain to depress enough to remove it. There really is no trick. Just have to find the 2 metal spring tabs that hold the bottom in place and push th, upwards. You can replace it without removing the vent. Just remove your instrument cluster.
09-05-2019, 03:57 PM
#29
We get these alot here at my work, even have a gold alero in today for what I'm guessing the problem is. (the owner pushed the hazard button so hard it pushed behind the dash and broke the bracket it sits in. But when one comes in we recommend a multi function switch and a hazard switch. Neither are hard to do. Remove center vent via to clips on the bottom side of vent, and then look left and up and a child could figure it out from there. For multi function switch, just remove steering column cover and you will see a tourx on the top side, romove that torx and wiggle mfs and it will pop loose, then remove the two connectors going into it, easy.. let me know if that didn't make sense
Do you happen to have a link or part number for the black plastic bracket that the hazard switch snaps into?
Sorry if it seems like I'm driving you crazy, as I emailed you as well.
Found the part number you posted earlier.
09-05-2019, 09:49 PM
#30
gm part # 22627609 is the bracket Bracket they break sometimes.
