Old 11-29-2009, 09:14 AM   #21
Before Cleaning MAF : 220 miles/tank
After Cleaning MAF : 310 Miles/tank
idle's a LOT better, runs smoother, i love it
Old 11-30-2009, 09:59 AM   #22
chevypower91
chevypower91 is on a distinguished road
Hey guys,
How do you go about cleaning the maf sensor (if it has one) on a 2.2 ecotec?
chevypower91 is offline   Reply With Quote
Old 07-21-2011, 09:29 PM   #23
foxsdaddy67
foxsdaddy67's Avatar
foxsdaddy67 is on a distinguished road
Send a message via Yahoo to foxsdaddy67
would carb cleaner work?
foxsdaddy67 is offline   Reply With Quote
Old 07-22-2011, 07:13 AM   #24
no. that shit is too strong and could easily damage it
Old 07-22-2011, 10:57 PM   #25
Williamleo
Williamleo's Avatar
Williamleo is on a distinguished road
Send a message via Yahoo to Williamleo
Sounds like a great Saturday job! Wally World of course didn't have the MAF cleaner, Car Quest was closed. Where did you get the right cleaner?
Williamleo is offline   Reply With Quote
Old 07-24-2011, 07:36 PM   #26
got mine from advanced. napa also has it.
Old 08-25-2011, 03:53 PM   #27
d_oz
d_oz is on a distinguished road
Could you guys take a picture or explain where I can find the MAF sensor on a 2000 alero gls
d_oz is offline   Reply With Quote
Old 08-25-2011, 04:02 PM   #28
WILLIAMLEO u know thats a pic of ur IAT right not MAF.
Old 08-25-2011, 04:03 PM   #29
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Even though I have a Cold Air Intake, the MAF is still basically in the stock location.
Old 08-25-2011, 04:22 PM   #30
d_oz
Shiwnath...i see you have aftermarket spark plug wires. did you have that professionally installed or DIY? Im having trouble accessing all the spark plugs and couldn't find a clear how-to on the forum. any info would be great.
Old 08-25-2011, 04:50 PM   #31
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Did it myself. I just pulled the old wires and felt for the plug and just removed with a spark plug socket and rachet. then felt for the hole and with the new spark plug in the spark plug socket, I manually screwed in the new plug then tightened with a rachet. It may help if you have a small bathroom mirror. As long as you keep note of the general area of where the spark plug should be, its not too difficult.
Old 10-26-2011, 07:42 PM   #32
Hellfire5670
Hellfire5670's Avatar
Hellfire5670 is on a distinguished road
i have 240,000 KM on my car.... maybe thats why i get no fuel mileage...
Hellfire5670 is offline   Reply With Quote
Old 10-26-2011, 07:55 PM   #33
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
There are plenty of things that cause poor mileage... dirty Air filter, spark plugs, ignition coils, spark plug wires, fuel filter, tire pressure and much more...at 240,000KM its probably would be a good thing to look into all of these as well as a dirty MAF if you haven't already.
Old 10-27-2011, 12:32 PM   #34
Hellfire5670
This i know i need to do i full tune on my car.. i will be changing the plugs and wires new intake system tires are always good ;D maybe ill change it while my car sits in the bush
Old 10-27-2011, 01:22 PM   #35
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
Also you should buy some throttle body cleaner and clean the throttle body too..its something a lot of people over look when doing general maintainace. If your throttlebody is dirty enough, it can hurt your gas mileage.
Old 10-27-2011, 05:37 PM   #36
Hellfire5670
i was thinking of this but wasn't sure if i should :P but that works! i used to have great fuel mileage but driving a day thats half a tank after i ge paid ill buy all the new plugs wires and cleaning maybe even a cold air!
Old 11-04-2011, 09:05 AM   #37
JakeBrake
JakeBrake's Avatar
JakeBrake is on a distinguished road
where is the MAF on a 2.2 ecotec?
2002 Oldsmobile Alero GX 5 Speed
Stage 2 Clutch
Cosmo Racing Intake
Polyuruthane motor Mounts
Magnaflow Muffler
JakeBrake is offline   Reply With Quote
Old 11-04-2011, 09:37 AM   #38
from what i understand there isn't one instead we have a MAP (mass air pressure sensor) and I believe it is as the air enters in past the throttle body
Old 11-04-2011, 10:42 AM   #39
Shiwnath
15.65 @ 87.3 MPH
Shiwnath's Avatar
A MAP sensor is a manifold absolute pressure sensor. The 3400 has both a MAP and MAF.. The 2.2 has only the MAP.. They both serve essentially the same purpose. Think of the MAP as an internal way to measure the volume of air and the MAF as an external way to measure the volume of air.
The MAF measures the rate of air flow to determine how much air your engine is intaking where as the MAP measures the pressure of the air to determine how much air your engine is intaking.
To me, a MAP is more accurate because it's closer to where the combustion happens. With a MAF, if you have an air leak just right after the MAF( such as forgetting to put the throttlebody gasket back on or an air hose leak), atleast the MAP can determine the actual air volume getting into the engine.
Old 11-04-2011, 11:29 AM   #40
JakeBrake
JakeBrake's Avatar
so is there no way to clean the MAP? in a 2.2 ecotec?
Stage 2 Clutch
Cosmo Racing Intake
Magnaflow Muffler
