10-28-2009, 12:43 AM
#21
Maybe I can earn 1/2 a point - Using a 200 Alero PCM to run the GM S/C on my 1999 Malibu... the 73 Olds needs a rear-end.
#22
/\/\ yay originality
10-28-2009, 01:10 AM
#23
I know some people who have more horsepower in their stereo systems than a couple hondas come with on their stock motor.
Like this...?!
Under construction...
10-28-2009, 03:34 AM
#24
A.S.S. Translator
this thread was rather pointless to begin with manwhore. You should know better dude. Like heineck said, you saw 2 at ASS this past year. Come on dude.
10-28-2009, 04:02 AM
#25
New and Improved
Ok i dont think anyone will object to this being locked....
10-28-2009, 08:09 AM
#26
lol this is funny, but on a side note I understand why so many people hook up Hondas.....they are crap to start with. 10 years ago I drove a civic si and man that think was slow not to mention the seats were uncomfortable and I felt like i was in a shuttle.
but I agree with cherry, some stereos have more HP then hondas lmao
10-28-2009, 08:59 AM
#27
I used to own hondas....
Honda= Had One Never Drive Again
Now quit being a dumbeff.... thats all i have to say
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
10-28-2009, 09:22 AM
#28
New and Improved
I will give $20 to the first admin who bans his ass
10-28-2009, 09:33 AM
#29
Ok i got maybe a noobish question. When an Alero gets turboed what is the max pressure you guys set up for? and then for the Honda what is the max pressure they set up for?
Also i got a kid at my school that says his turboed honda has 300 HP, is he filling me full of shit or could that be obtainable.
10-28-2009, 09:50 AM
#30
with supporting mods it's very attainable. as far as boosting aleros... i've seen for the most part people sticking close to 6-7lbs... spy help me out...
to put it in perspective. a stock GSX boosts like 7, my wrx stock pushes 14. i've seen 4g63s with over 90lbs.
10-28-2009, 09:51 AM
#31
Well, Ion has to be pushing 300 or so from his LD9, and I believe Spyhunter is 500+ at the crank. There really is no limit for how much you can pump out of your motor, but there is a limit to how much the motor can take. You have to build your motor to handle the power you want to see.
GX Coupe
Dropped and Blown
10-28-2009, 09:54 AM
#32
He is asking about psi.... not hp
10-28-2009, 09:58 AM
#33
/\/\ well i was asking if 300 HP out of a civic sounded right.
6-7 LBS is that like putting in a turbo on a stock engine, or is that with the engine built for it. 6-7 LBS seems kinda low, i guess i have only driven one car with a turbo and that was for behind the wheel and that was in a WRX (it was a blast )
10-28-2009, 09:59 AM
#34
i know the stock 3.4 can handle approx 12psi, but most people stay around 6-7, because the tranny can't take it.
10-28-2009, 10:04 AM
#35
Now someone has to spend time to delete this thread!
10-28-2009, 10:07 AM
#36
So when most people do like serious turbo work, they replace there tranny with a perfomance one??
10-28-2009, 10:56 AM
#37
usually.. especially with the alero's.
They rebuild the trans to performance spec. LSD, Upgraded Clutches, Higher Stall Torque Converter
And if im correct. C2 is running 13.8 lbs boost on his built LD9
Nickname : Midnyte
10-28-2009, 11:16 AM
#38
yes. check blackjack's build thread. details are there, as to which tranny. (i'm no engine guy... i know basics)
10-28-2009, 11:20 AM
#39
BJ worked in the 4t65HD
Nickname : Midnyte
10-28-2009, 11:37 AM
#40
^^^ i heard that is hard to do with all the fab work needed
