Old 11-09-2009, 07:18 PM   #1
01OldsAleroGt
01OldsAleroGt's Avatar
01OldsAleroGt is on a distinguished road
Send a message via AIM to 01OldsAleroGt Send a message via MSN to 01OldsAleroGt Send a message via Yahoo to 01OldsAleroGt
Best Spark Plugs for tune up
Ok so i searched the threads.. found nothing.
Stock 3400 w/ a Cone Filter on the MAF
got NGK V-Power in them from my last tune up 35k miles ago
Car is running ok. one of the plugs is starting to eff up.
What would be a good idea for plugs. I tried searching for the AC Delco Rapid Fires.. but nobody stocks em anymore and heard they no longer produce em. and also heard that NGK produces AC Delco plugs.
Would the G-Power Platinum plugs be perfect for my car ? or any advice on what should i use.. im working w/ a budget too.
I just don't want to get plugs then foul out 5-10k down the road
Also forgot to add. I have no catalytic converter but i will be replacing within the next few months w/ a hi flow
2001 Oldsmobile Alero GL Sedan LA1 3400 SFI V6
Nickname : Midnyte
01OldsAleroGt is offline   Reply With Quote
Old 11-09-2009, 07:33 PM   #2
ACDelco #41-101
Old 11-09-2009, 07:52 PM   #3
AC delco rapid fire
Old 11-09-2009, 08:01 PM   #4
Originally Posted by JLw7123 View Post
AC delco rapid fire
you skim
get the ones cliff showed you
Old 11-09-2009, 08:01 PM   #5
rida125
rida125's Avatar
rida125 is on a distinguished road
Send a message via Skype™ to rida125
well i just put in the platinum plus
<img src=http://i896.photobucket.com/albums/ac167/rida125/beach5-1-1.gif border=0 alt= />
rida125 is offline   Reply With Quote
Old 11-09-2009, 08:05 PM   #6
01OldsAleroGt
ok so i checked a local advanced auto. the part number cliff gave me was for the iridiums for 6.49 a piece
i gave the number #14 from the webpage it came up autolites
Nickname : Midnyte
Old 11-09-2009, 08:07 PM   #7
Originally Posted by Nate's Alero View Post
you skim
I got some for my other alero. When did they stop making them.
Old 11-09-2009, 08:42 PM   #8
i found them, dont think they would discontinue such a great plug
Old 11-09-2009, 09:41 PM   #9
01OldsAleroGt
well thanks for the help of you guys. i had to grill the AZ associates harder. they still have em. just it was a pain in the ass to find for some odd reason
Nickname : Midnyte
Old 11-10-2009, 04:17 PM   #10
what plugs did u end up getting.
Old 11-17-2009, 12:57 PM   #11
alerogls001
alerogls001's Avatar
alerogls001 is on a distinguished road
I actually remember reading a long thread about spark plugs.... some people had diff results. I been using NGK without any problems whatsoever.
MP Racing CAI, Pacesetter Exhaust, and PCM. High flow CAT. KYB GR2 struts. Canuck Motorsport Springs. Cross drilled rotors. Stern ST18 17" rims.
alerogls001 is offline   Reply With Quote
Old 11-17-2009, 02:25 PM   #12
01OldsAleroGt
i haven't changed em yet. got laid off AGAIN. X.X but workin for pizza delivery for now. But im def thinkin AC Delco Rapid's but any body have any luck with autolite platinums.. or STAY AWAY from em
Nickname : Midnyte
Old 11-25-2009, 05:51 AM   #13
Kilroy
Kilroy's Avatar
Kilroy is on a distinguished road
Originally Posted by Cliff8928 View Post
ACDelco #41-101
Yay!!! I remembered the right numbers!! Canadiantire guy said they were for the 2000 - 2004, not the 1999. Same engine, so I got them anyway. Then he said that the Platinum one where recommended for the 1999, and that was why they never listed the Iridiums as being for the 1999 model. Got them anyway. CAN$18.xx for two. Wondering if I should go with new wires, just to be safe?? Pretty sure the originals are still on. If I get new wires, what is recommended?? (maybe blue ones to match my car paint colour??
Kilroy is offline   Reply With Quote
Old 11-25-2009, 06:41 AM   #14
anything not AC Delco will NOT work in the 3400, just letting you all know
DIS waste spark systems ruin copper core plugs
Old 11-25-2009, 08:14 AM   #15
i went in to get an oil pan bolt.. and the tard behind the counter directed me over to the standard nuts and bolts.
I looked at him like.. Then specified... "...the bolt you remove to drain the oil..." (in bolt where is where is started talking slow, like he didn't speak english)
he said "yep.. thats these, you need to know what size and length"
"wow... you can't be more wrong. thanks" And i went to NAPA. No more autozone for me. (unless its something super common that i know where it is)
Old 11-25-2009, 09:42 AM   #16
AZ here is great, AAP are the idiots...
Old 11-25-2009, 04:34 PM   #17
Carquest is the spot here.
Delco plugs are supposedly the best for aleros. I didn't know anyone made plugs besides NGK until i was about 16.
Old 11-25-2009, 04:53 PM   #18
Autolite is a Ford plug. I had them in the Alero, didn't like them
Old 11-25-2009, 04:54 PM   #19
CBLOHM3400
Trying To Help
CBLOHM3400's Avatar
CBLOHM3400 is on a distinguished road
Send a message via Yahoo to CBLOHM3400
if you go to the parts counter and ask for 41-101 ac delcos and pull one out of the box it has nkg stamped on the hex part of the plug
03 OLDS ALERO
CBLOHM3400 is offline   Reply With Quote
Old 11-27-2009, 01:46 PM   #20
A57
A57's Avatar
A57 is on a distinguished road
Send a message via Yahoo to A57
E3 plugs
http://www.e3sparkplugs.com/
the best Ive used to date...got them in my saturn and getting 40 mpg on the highway..
as seen used on Horse power tv..
BUILDING A V8 ALERO 2DR
A57 is offline   Reply With Quote
