Old 03-25-2010, 07:45 PM   #21
Chris2000
Chris2000 is on a distinguished road
Just got my oil changed, unfortunately my dad loves to have all the tools in his trunk of his car (my old car; 99 ford contour) because its a pos. So i have no sockets to get down in there to change the plugs. Oh well, maybe later tonight when he gets home. He also keeps the reader in his car too.
Already I can feel the car smoother already and it was pretty damn smooth before.
Here are pictures of where the brake booster line is.
Do not pull the clamp off! Pull the piece out of the gromet. It took me a good 5 minutes to loosen it up.
What I did was since it was taking me so long to get it out I turned the car off and took my time getting it out. After I got it out I put it back in, but not all the way, just enough to have it in but pull it out easily.
Then I turned the car back on and pulled the line out, poured the seafoam and then turned the car off immediately after just as told to do.
P.s. when you pull out the brake booster line it will make a "psssst" sound. It is from all the pressure built up, its normal.
P.s.s. No need to bleed brakes after, I thought because I was taking so long to get it in there I let too much air in and needed to do it, but it had no effect on the brakes.
Chris2000 is offline   Reply With Quote
Old 10-27-2011, 06:27 PM   #22
Hellfire5670
Hellfire5670's Avatar
Hellfire5670 is on a distinguished road
Originally Posted by jabartram View Post
i used this last time, works well and is less expensive than seafoam and gm top engine cleaner.
http://www.amsoil.com/storefront/apf.aspx
NOTE: Not to be used with vehicles that have MAF sensors.
Hellfire5670 is offline   Reply With Quote
Old 10-27-2011, 10:24 PM   #23
I did it the other day and I notice a difference.
Old 01-10-2012, 04:33 AM   #24
hotrod_garage
hotrod_garage is on a distinguished road
Sounds like we have a "few" tuner wanna bees. I've used the top end stuff of various brands and NONE of them work worth a damn.
The "pssssss" is NOT press, it's vacuum. Also any time you put anything of a lessor viscosity into your oil it will lower it. Plus oil has detergent in it. You guys can do whatever you want, but if you don't even know where the booster vacuum line is let alone what it does or how it works, should you really even be opening the hood?
hotrod_garage is offline   Reply With Quote
