10-25-2010, 10:46 PM
#21
That's a sweet mod bmxer! Nice job!
10-26-2010, 02:39 AM
#22
Inside tails as brake light also makes it bright as hell lol had that on mine
10-29-2010, 02:16 PM
#23
Originally Posted by tw0123
looks good... when i did mine though, i left the reflective strips clear, that way the cops cannot harass me (as much!!) for having tinted tail lights...
How are the strips glowing so much? Did you use a flash?
It would look awesome if our tails actually lit up that way.
2K 3.4L 4DR GLS
10-29-2010, 09:46 PM
#24
that is really sweet. How did you do that, just tape off the strips??
That gave me an idea, if thats all you did how would doing what you did and also having the strips on the outside of the lights look???
10-30-2010, 08:17 AM
#25
you just tape off the strips before doing it, really not that hard just takes a little bit of patiences. took me longer to do that then tinting my tails
10-30-2010, 09:27 AM
#26
ok thats what i though, cuz i dont want to copy what you did, i was thinking the reflector strips that are around the lights and the one you taped off, you think that would look nice, or just odd?
10-30-2010, 11:12 AM
#27
honestly I thought of it too but I thought it would look odd, don't worry its ok to copy its not a math test :P
02-01-2011, 07:35 PM
#28
i too have done the same kind of i put a strip on the red and painted the rest black
02-01-2011, 07:36 PM
#29
i did exactly how the pic was up top
02-01-2011, 08:40 PM
#30
Originally Posted by Gr1m
bmxer...you should wire up your inside tails to act with the brake lights as well, takes 2 minutes and looks much better.
How do you go about doing this?
02-01-2011, 09:47 PM
#31
probably wire it up to your 3rd brake light. I should do that
02-01-2011, 09:51 PM
#32
Originally Posted by hok666
probably wire it yup to your 3rd brake light. I should do that
yes there is an empty pin hole on the trunk mounted bulb socket. i took a piece of wire and stripped the casing back about 2 inches, folded it, and stuck it in the pin hole. then i just used some silicone to keep the wire in place. after that you just run the two wires to the power wire for the third brake light, tap into it and done. you have to change the bulb to a 3157 though because it obviously needs to be a dual filament.
02-01-2011, 10:46 PM
#33
I'm not quite understanding this part
02-02-2011, 06:37 AM
#34
ya got a pic by chance?
02-05-2011, 12:12 PM
#35
what gauge of wire did you use?
02-05-2011, 01:05 PM
#36
I think autozone sells 16ga that might be good enough
02-05-2011, 09:06 PM
#37
yes its pretty thin, i would recommend using hot glue rather then silicone as previously mentioned, the cure time for silicone is way too long for that job.
02-05-2011, 09:16 PM
#38
i agree hot glue would be faster. reason i used silicone was my car was going to be sitting for a few days and i figured the silicone would last longer.
02-05-2011, 09:18 PM
#39
if you look at the bulb plug for the inner tail light you will see an empty hole with no wires going into it. i folded the wire just to make sure it would make good contact inside the plug
ill snap a few pics tomorrow when its lighter out.
02-05-2011, 10:08 PM
#40
Koo, Ive been waiting impatiently :P
