Old 12-31-2010, 06:29 PM   #61
Cashdollar2009
Cashdollar2009's Avatar
Originally Posted by Ryan from Ohio View Post
When you bend ports the port length is measured from the center of the port, not a port wall side.
So it would start in the center of the port at the front of the box. Not 3/4" in...
Im gonna guess neither of you realized this.
Sure you can build it as shown, but the tuning would be off. Depends on how accurate you want to get...
Referring to me?
Under construction...
Old 12-31-2010, 07:43 PM   #62
Afugy
I poop alot
Afugy's Avatar
Afugy is on a distinguished road
Originally Posted by Cashdollar2009 View Post
Referring to me?
ROFL, he wasn't talking to me.
Afugy is offline   Reply With Quote
Old 01-01-2011, 10:57 AM   #63
Referring to me?
Yes. Since you called out 19" and he went 19" along one edge and wasnt corrected.
Either you didnt know it or missed it.
I miss shit all the time so dont feel bad!
Old 01-02-2011, 04:17 AM   #64
Bigshot44
Bigshot44's Avatar
Bigshot44 is an unknown quantity at this point
hopefully this will be my last diagram. hows it look?
thanks again for the help.
and going back to the beginning of the thread i cant use either of those amps cause theres no way to get them running at 3 ohms :/
are there any other options other than the JL 1000/1v2
2003 Olds Alero 2.2L Eco
Ttop191: who gives a damn what everyone else thinks, if you are proud of it thats all that matters, dont let others persuade you into thinking what you like is wrong.
Bigshot44 is offline   Reply With Quote
Old 01-02-2011, 10:20 AM   #65
That port MUST be 3" off the back wall.
Why cant you use either of the amps?
If the amps are stable to 2 Ohms bridged or less then you can.
You wont find amps rated at 3 ohms.
Old 01-02-2011, 12:37 PM   #66
scott192
scott192 is on a distinguished road
i ran a w7 om my mrp-m2000 at 3 ohm worked great!
parts so far: 10000k hid heads and fogs, alpine INAW900, bluetooth, backup camera, alpine mrp-m2000, 18fi btl, 270amp mechman alterntor, 2 Redtop Batt's, all LED lights and color changing signals white/amber (every bulb other then dummy lights) and limo back 3 and 20% in the front and tinted tails
check out my car http://www.youtube.com/user/scott192
Well I know my car is female because she was bleeding for 7 days and didnt die!
scott192 is offline   Reply With Quote
Old 01-03-2011, 06:55 AM   #67
Bigshot44
Bigshot44's Avatar
how would you wire the amp into a 3 ohm load?
Old 01-03-2011, 10:55 AM   #68
Both + leads into the positive and both negs into the neg.
