Old 03-21-2011, 08:40 PM   #1
colonel6632
colonel6632's Avatar
Brake Upgrade Parts List
hey guys, my brakes are failing all around (my car doesn't stop, the brake line in the rear has a hole in it, and my front caliper is leaking)
anyways. i'm upgrading all the brakes and everything. i'll tell you what i want/ordering, and you correct me before i actually order it.
Big Brake Kit from MPRacing
http://www.mpracing.org/store/index....&productId=370
*** will i be ok with the ceramic or should i opt out for the carbon metallic?***
Drilled And Slotted Rotors
http://cgi.ebay.ca/XS-CROSS-DRILLED-SLOTTED-FRONT-SET-BRAKE-DISC-ROTORS-/380319331266?pt=Motors_Car_Truck_Parts_Accessories &fits=Model%3AImpala|Year%3A2002&hash=item588ccc73 c2
Stainless Steel Brake Lines
http://cgi.ebay.ca/G-Stop-Brake-Line...=item1de4eeafd
anyone know where i can get bigger calipers for the rear while im at it?
what have i forgotten or missed
1300w 8 speaker stereo, power window conversion, heated leather seats, 16" rims, high & low hids, auto dimming rear mirror, speedbuilt front and rear sway bars, poly bushings all around.
1994 GMC Sierra w/350 tbi 4l60e
aftermarket deck, leveling keys, toolbox w/ 2 batteries, indestructible
Old 03-21-2011, 08:57 PM   #2
Go to Rockauto.com
Front
98-02 Camaro calipers "semi-loaded" with brackets
00-05 Impala slotted and cross drilled rotors
Around $300
Rear
2005 Pontaic Grand Prix GXP calipers "loaded" with pads and brackets
2005 Pontaic Grand Prix GXP cross drilled rotors
Around $250
Granted I opted to go with ceramic pads all around. A lot less dust!!
Jammed my brakes twice so far. Once for fun and testing and my eyes fell out, the second a panic stop to not run a red light at 65 MPH (highway) and stopped 50 feet short of the intersection when stock would have put me thru the light
Old 03-21-2011, 10:17 PM   #3
colonel6632
life saver redog. i'll do what you say.
i dont need bracket bushings for the calipers or anything. just basically order whats on your list?
thoughts on the brake lines?
Old 03-22-2011, 03:13 AM   #4
Everything bolts up like a regular brake change...
Also, it doesn't make a difference if you order rotors for an Impala or a Camaro. They're the same part number.
Old 03-22-2011, 04:04 PM   #5
The rear brackets take a little bit of hammer to fit between the backing plate and the dust shelid, but it fits
Old 03-22-2011, 06:32 PM   #6
jhubbz
⌘ Irish Pride
jhubbz's Avatar
I'm gonna go ahead and throw this out there, but if I do just the fronts, I would need to buy new pads that fit the camaro calipers... correct?
Done lost my mind
Old 03-22-2011, 06:38 PM   #7
G.I.Ceo
G.I.Ceo's Avatar
G.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond reputeG.I.Ceo has a reputation beyond repute
Don't you also need a rim that is 17" or bigger for this upgrade to work?
G.I.Ceo is offline   Reply With Quote
Old 03-22-2011, 06:44 PM   #8
strtrydr
strtrydr's Avatar
IIRC ... The figue is rotor size plus 4" ... so this swap (12" rotors) should fit under most 16" wheels.
Old 03-22-2011, 07:39 PM   #9
XanderWiFi
XanderWiFi's Avatar
Hopefully this isn't a dumb question: but do you have rear drum brakes or the rotors?
Old 03-22-2011, 10:14 PM   #10
Greencoupe2.2
Greencoupe2.2's Avatar
Greencoupe2.2 is on a distinguished road
It looks like your car has 15's so I think your going to have to get new wheels to do the front brake upgrade. (someone correct me if Im wrong)
Greencoupe2.2 is offline   Reply With Quote
Old 03-22-2011, 11:17 PM   #11
jhubbz
⌘ Irish Pride
jhubbz's Avatar
I've got 16" so hopefully I'm good
Done lost my mind
Old 03-23-2011, 02:21 AM   #12
16" wheels should be good for the F-Body calipers.
Old 03-23-2011, 02:22 AM   #13
I haven't tried my 16 inch stockers on there yet, but I know for a fact you will need a new spare tire. the 15 inch compact spare will not fit this set-up. I've seen Alero stock 16's on this set up. Also 16 inch "skinny spoke" Grand Prix rims fit well too
You can convert drums to rotors, but IDK how. I've never done it
Old 04-09-2011, 01:25 AM   #14
Originally Posted by Redog View Post
Go to Rockauto.com
Front
Around $300
Rear
Around $250
I was talking with my neighbour, who is a GM mechanic, and he was saying I could just use the GXP set up for both front and rear... what is the difference between using the front's and the Camaro/Impala combo?
Old 04-09-2011, 01:50 AM   #15
The GXP uses a 13" rotor so that pushes your minimum wheel size to 17". There is a bracket setup being made to use the C5/C6 corvette parts. It's a 12.98" directional rotor.
Old 05-31-2013, 09:18 PM   #16
02AleroGLS
02AleroGLS's Avatar
02AleroGLS is on a distinguished road
Smile camaro brakes!
I keep reading where everyone is doing f body front brakes,but im wondering if the v6 base model,v6 RS,and Z28,and the SS all have the same size of brakes!?!? Im kinda lost on this. I get a big hookup on car parts at our local NAPA due to being good friends with the manager lol!! Someone please let me know.. I'm very interested in doing that upgrade.. Thanks in advance!!
02AleroGLS is offline   Reply With Quote
Old 06-02-2013, 02:19 AM   #17
They're all the same... Just need to be 98-02
Old 06-02-2013, 02:38 PM   #18
02AleroGLS
02AleroGLS's Avatar
Smile camaro brakes
Alrright! I appreciate it. I just wanted to make sure
Old 06-02-2013, 04:03 PM   #19
Nas Escobar
Nas Escobar's Avatar
That's right, if you have Camaro calipers you need Camaro pads. Of course, you can also use the Corvette stuff from the same time frame... I believe it's C5. They bolt right on, but you're also guaranteeing that you'll need 17" wheels since the Corvette calipers have cooling fins on them.
I have a write up on here if anyone is interested in converting their rear drums to disc. It's not complicated, just somewhat annoying.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Old 06-03-2013, 12:03 AM   #20
The cooling fins on the Corvette/GTO/XLR calipers just extend further on the caliper. Either way, the C5 and C6 as well as the GTO and XLR calipers will fit.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
