Old 08-18-2004, 01:38 PM   #1
Daytona
ALEROMOD RAPIST
Daytona's Avatar
Daytona is on a distinguished road
Here are the formulas for calculating motorcycle and automotive performance.
* Many of the formulas use the value of pi which is 3.1415927
* Some formulas contain notation such as ^2 which means "squared" or ^3 which means "cubed"
Formulas for Calculating Performance
Convert between 1/4 mile and 1/8 mile ET's
1/4 mile ET = 1/8 mile ET x 1.5832
1/8 mile ET = 1/4 mile ET / 1.5832
Calculate 1/4 mile ET and MPH from HP and Weight
ET = ((Weight / HP)^.333) * 5.825
MPH = ((HP / Weight)^.333) * 234
Calculate HP From ET and Weight
HP = (Weight / ((ET/5.825)^3))
Calculate HP From MPH and Weight
HP = (((MPH / 234)^3) * Weight)
Calculate 0-60 Times
T(0-60) = (2 x vehicle weight/Max. known engine torque) --> all raised to the .6 power
Formulas for displacement, bore and stroke
pi/4 = 0.7853982
cylinder volume = pi/4 x bore^2 x stroke
stroke = displacement / (pi/4 x bore^2 x number of cylinders)
Formulas for compression ratio
(CylVolume + ChamberVolume) / ChamberVolume
chamber volume = cylinder volume / compression ratio - 1.0
displacement ratio = cylinder volume / chamber volume
amount to mill = (new disp. ratio - old disp. ratio / new disp. ratio x old disp. ratio) x stroke
Formulas for piston speed
piston speed in fpm = stroke in inches x rpm / 6
rpm = piston speed in fpm x 6 / stroke in inches
Formulas for brake horsepower
horsepower = rpm x torque / 5252
torque = 5252 x horsepower / rpm
brake specific fuel consumption = fuel pounds per hour / brake horsepower
bhp loss = elevation in feet / 1000 x 0.03 x bhp at sea level
Formulas for indicated horsepower & torque
horsepower = mep x displcement x rpm / 792,00
torque = mep x displacement / 150.8
mep = hp x 792,000 / displacement x rpm
mechanical efficiency = brake output / indocated output x 100
friction output = indicated output - brake output
taxable horsepower = bore2 x cylinders / 2.5
Formulas for air capacity & volumetric efficiency
theoretical cfm = rpm x displacement / 3456
volumetric efficiency = actual cfm / theoretical cfm x 100
street carb cfm = rpm x displacement / 3456 x 0.85
racing carb cfm = rpm x displacement / 3456 x 1.1
Formulas for tire size & their effect
effective ratio = (old tire diameter / new tire diameter) x original ratio
actual mph = (new tire diameter / old tire diameter) x actual mph
Formulas for g force & weight transfer
drive wheel torque = flywheel torque x first gear x final drive x 0.85
wheel thrust = drive wheel torque / rolling radius
g = wheel thrust / weight
weight transfer = weight x cg height / wheelbase x g
lateral acceleration = 1.227 x raduis / time^2
lateral weight transfer = weight x cg height / wheel track x g
centrufugal force = weight x g
Formulas for shift points
rpm after shift = ratio shift into / ratio shift from x rpm before shift
driveshaft torque = flywheel torque x transmission ratio
Formula for instrument error
actual mph = 3600 / seconds per mile
speedometer error percent = difference between actual and indicated speed / actual speed x 100
indicated distance = odometer reading at finish - odometer reading at start
odometer error percent = difference between actual and indicated distances / actual distance x 100
Formulas for MPH RPM gears & tires
mph = (rpm x tire diameter) / (gear ratio x 336)
rpm = (mph x gear ratio x 336) / tire daimeter
rear gear ratio = (rpm x tire diameter) / (mph x 336) OR = (Tire radius X RPM / 168) / MPH
ideal rear gear ratio = (RPM X Tire Diameter) / (336 X Trap Speed MPH)
tire diameter = (mph x gear ratio x 336) / rpm
tire radius = (mph x gear ratio x 168)/ rpm
Formulas for weight distribution
percent of weight on wheels = weight on wheels / overweight x 100
increased weight on wheels = [ distance of cg from wheels / wheelbase x weight ] + weight
Formulas for center of gravity
cj location behind front wheels = rear wheel weights / overall weight x wheelbase
cg location off-center to heavy side = track / 2 - [ weight on light side / overall weight ] x track
cg height = [ level wheelbase x raised wheelbase x added weight on scale / distance raised ] x overall weight
Daytona is offline   Reply With Quote
Old 08-18-2004, 02:40 PM   #2
Sundayalero
Sundayalero is an unknown quantity at this point
<span style=\'font-size:8pt;line-height:100%\'>Every now and then when your life gets complicated and the weasels start closing in, the only real cure is to load up on heinous chemicals and then drive like a bastard from Hollywood to Las Vegas. Just roll the roof back and screw it on, grease the face with white tanning butter and move out with the music at top volume, and at least a pint of ether.
-From the book Fear and Loathing in Las Vegas by Hunter S. Thompson </span>
Sundayalero is offline   Reply With Quote
Old 08-18-2004, 11:55 PM   #3
FormulaNERD
yea... alot of formulas are car/engine specific.
the 1/4 ET formula was off by about a second for me.
Old 08-19-2004, 07:58 AM   #4
Daytona
ALEROMOD RAPIST
Daytona's Avatar
Which formula? Converting from/to 1/8-mile?
Don't forget that these are mathmatical calculations taking into account average textbook results. there are always variable mitigating factors which could sway the actual results one way or another to a certain extent - more so for performance/time calculations than for, say, displacement or compression ratio.
Old 08-19-2004, 04:46 PM   #5
FormulaNERD
yea, i realize that, i was looking somewhere that had some formulas based on different cars. olds was closer to 1.514 or something like that...
Old 10-23-2006, 08:53 PM   #6
boostnsrt
my brain hurts now, thanks
