Closed Thread
Old 09-21-2011, 07:55 PM   #1
1999-2004 Engine Fastener Torque specs
Directly from General Motors:
Inch pounds are highlighted
  • Accelerator Control Cable Bracket Bolt: 89 in lbs
  • Air Injection Check Valve (Cali emissions): 15 ft lb
  • Air Injection Check Valve front bracket Bolt and Nut (cali emissions): 18 ft lbs
  • Air Injection Valve Nut(Cali emssions): 89 in lbs
  • Air Injection valve pipe adapter: 22 ft lbs
  • Air Injection check valve rear bracket nuts (Cali emissions) 18 ft lbs
  • Air injection solenoid bolt(Cali emissions): 89 in lbs
  • Camshaft Position Sensor bolt: 89 in lbs
  • Camshaft Spocket bolt: 103 ft lbs
  • Camshaft Thrust Plate Screw: 89 in lbs
  • Conncetion Rod Bearing Cap Nut: 15 ft lbs + 75*
  • Coolant Drain Plug: 14 ft lbs
  • Coolant Temperature Sensor: 17 ft lbs
  • Crankshaft Balancer Bolt: 76 ft lbs
  • Crankshaft Main Bearing Cap Bolt/Stud: 37 ft lbs + 77*
  • Crankshaft Oil Deflector Nut: 18 ft lbs
  • Crankshaft Position Sensor Bolt-Front Cover: 89 in lbs
  • Crankshaft Position Sensor Stud-Side of block: 98 in lbs
  • Crankshaft Position Sensor Wiring Bracket bolt: 37 ft lbs
  • Cylinder Head Bolt: 37 ft lbs + 90*
  • Drive Belt Shield Bolt: 89 in lbs
  • Drive Belt Tensioner Bolt: 37 ft lbs
  • EGR Valve to EGR Valve Pipe Bolt: 18 ft lbs
  • EGR Valve Adapter Pipe to Exhaust Manifold Nut: 18 ft lbs
  • Engine Fly Wheel Bolt: 52 ft lbs
  • Engine Front Cover Bolt-Large: 41 ft lbs
  • Engine Front Cover Bolt-Medium: 35 ft lbs
  • Engine Front Cover Bolt-Small: 15 ft lbs
  • Engine Mount Bracket Bolt: 43 ft lbs
  • Engine Mount Lower Nut: 32 ft lbs
  • Engine Mount Strut and lift Bracket Bolt-Engine Left Rear: 52 ft lbs
  • Engine Mount Strut Bolt/Nut: 35 ft lbs
  • Engnie Mount Strut Bracket Bolt-Upper Radiator Support: 21 ft lbs
  • Engine Mount Strut Bracket Bolt-Vehicle Right Side: 37 ft lbs
  • Engine Mount Upper Nut: 35 ft lbs
  • Engine Oil Pressure Indicator Switch: 115 in lbs
  • Engine Wiring Harness Bracket Bolt: 115 in lbs
  • Exhaust Crossover Pipe Heat Shield Bolt: 89 in lbs
  • Exhaust Crossover Pipe Nut: 18 ft lbs
  • Exhaust Manifold Hest Shield Bolt: 89 in lbs
  • Exhaust Manifold Nut: 12 ft lbs
  • Exhaust Manifold Stud: 13 ft lbs
  • Fuel Feed Pipe to Fuel Injector Rail Nut: 13 ft lbs
  • Fuel Injector Rail Bolt: 89 in lbs
  • Fuel Pipe Bracket Bolt/Stud: 37 ft lbs
  • Fuel Pipe Clip Bolt: 71 in lbs
  • Fuel Return Pipe to Fuel Injector Rail Nut: 13 ft lbs
  • Generator Bracket and Front Engine Lift hook Bolt: 37 ft lbs
  • Heated Oxygen Sensor: 31 ft lbs
  • Heater Inlet pipe Nut: 18 ft lbs
  • Ingition Coil Bracket Bolt/Nut/Stud: 18 ft lbs
  • Intake Manifold Coolant Pipe Bolt: 89 in lbs
  • Knock Sensor: 14 ft lbs
  • Lower Intake Manifold Boilt: 115 in lbs
  • MAP Sensor Bolt: 44 in lbs
  • Oil Cooler Connector: 37 ft lbs
  • Oil Cooler Hose Fitting: 14 ft lbs
  • Oil Cooler Pipe Bracket Bolt: 89 in lbs
  • Oil Filter: 115 in lbs
  • Oil Filter Bypass Hole Plug: 14 ft lbs
  • Oil Filter Fitting: 29 ft lbs
  • Oil Galley Plug-1/4 inch: 14 ft lbs
  • Oil Galley Plug-3/8 inch: 24 ft lbs
  • Oil Level Indictor Tube Bolt: 18 ft lbs
  • Oil Level Sensor Bolt: 89 in lbs
  • Oil Pan Bolt: 18 ft lbs
  • Oil Pan Drain Plug: 18 ft lbs
  • Oil Pan Side Bolt: 37 ft lbs
  • Oil Pump Cover Bolt: 89 in lbs
  • Oil Pump Drive Clamp Bolt: 27 ft lbs
  • Oil Pump Mounting bolt: 30 ft lbs
  • Spark Plug: 20 ft lbs
  • Thermostat Bypass Pipe to Cylinder Head Nut: 18 ft lbs
  • Thermostat Bypass Pipe to Engine Front Cover Bolt: 106 in lbs
  • Thermostat Bypass Pipe to throttle Body Nut: 18 ft lbs
  • Throttle Body Bolt/Stud: 18 ft lbs
  • Timing Chain Dampener Bolt: 15 ft lbs
  • Transaxle-to-Engine Bolts: 55 ft lbs
  • Upper Intake Manifold Bolt/Stud: 18 ft lbs
  • Valve Lifter guide Bolt: 89 in lbs
  • Valve Rocker Arm Bolt: 14 ft lbs + 30*
  • Valve Rocker Arm Cover Bolt: 89 in lbs
  • Water Outlet Bolt: 18 ft lbs
  • Water Pump Bolt: 89 in lbs
  • Water Pump Pulley Bolt: 18 ft lbs
Redog is offline
Closed Thread
