Old 05-07-2012, 11:59 PM   #21
DJx79x
DJx79x's Avatar
DJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond reputeDJx79x has a reputation beyond repute
I think i have this problem because this kept happening to me and i thought it was because i needed my brakes serviced (which I did) but I recently had this happen after they were serviced so now idk what do because i have access to none of the things required to do what is pictured here.
DJx79x is offline   Reply With Quote
Old 05-16-2012, 07:16 AM   #22
sorry iv been out of the picture for a few weeks, a lot of it you can do with minimal tools. all you have to do is lift the car (how ever you choose to do it) and start with checking your wheel bearings for play. if theres play then replace them. next thing just check your sensor connectors for corrosion, chafes or broken wires. typicaly doing that will tell you whats going on, usualy you will not have to go as far as i did in the first write up.
Old 03-25-2013, 12:58 PM   #23
added something i ran into last weekend at the bottom of my first post.
Old 10-31-2022, 07:34 PM   #24
zzyzzx
zzyzzx's Avatar
This is also what the internet suggests. And mine only started giving me an issue after 6 days of rain.
Old 01-10-2023, 06:48 AM   #25
zzyzzx
zzyzzx's Avatar
Mine ended up being a broken green wire on the right side. So I spliced it. so far so good, but I bet the other orange/brown (whatever) conductor goes bad next.
I do wonder if the left side goes bad as well, because wiring harness replacement pieces are sometimes sold in pairs for slightly more then just the right side.
