Old 01-11-2012, 09:54 PM   #1
spc2125
spc2125's Avatar
Exclamation Install Intake How-To
This How-To is for the 2.2 ecotec
It arrived in about 7 business days.
Expected gain 5-15 hp
This is how it arrived
Here is a copy of the instructions given in the package
Because I had already removed my stock air filter and put a cone filter on, i skipped all the way to step 7
Remove the IAT sensor boxed in blue on the far right, remove the cable that connects into the throttle body boxed in blue in the middle, and then unclamp the vacuum hose attached to the valve cover in the blue box on the far left.
To remove the plastic throttle body piece, there are screws around the clamps in the red box. then there is one underneath the throttle body.
After you detach everything it should look like this
Next Install the air intake kit with Elbow coupler on the throttle body and follow by the longest air intake.
Then install the short air intake pope with air filter on the second air intake pipe just like the picture shows
Connect the given blue vacuum hose to the valve cover and the farthest left outlet (boxed in blue)
Connect the black cable to the next outlet (boxed in blue)
The next part is CRITICAL so pay attention.
In order to attach the IAT sensor you will need to remove the other half of the plug in the old intake.
Heres a look from the inside
What I did was cut a little bit around the rubber grommet and then pried it out.
Then take that piece and stick it in the grommet in the new intake (it will be really tight so make sure you dont push the grommet through because then youll have to unscrew the elbow piece and take it out)
Then lastly take plug in the IAT sensor
I would recommend getting a different filter because its crap compared to whats out there. (preferably a K&N filter)
A common problem that could arise is your "Trac Off" light will come on and that is because the IAT sensor isnt plugged in right.
If you think it is plugged in correct and/or corrected the problem and the "Trac Off" light is still on....
Disconnect your battery. Wait 10 minutes. Connect. and hopefully it will go gone.
just call me "Doc"
Check out my alero!
Aleromod Showcase Video
Old 01-12-2012, 08:05 PM   #2
Math-u
Math-u's Avatar
Math-u is an unknown quantity at this point
Well. i might as well install it too^^
Any special tool require?
2003 Alero GX 2.2L Eco MT.
Math-u is offline   Reply With Quote
Old 01-12-2012, 08:35 PM   #3
spc2125
spc2125's Avatar
only pliers and a screwdriver
but if you have the stock air filter still youll prob need a ratchet and maybe a 7mm
just call me "Doc"
Check out my alero!
Old 05-14-2013, 05:46 PM   #4
S8track16
S8track16's Avatar
S8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond reputeS8track16 has a reputation beyond repute
Could you possibly post the pictures for this How-To again?
S8track16 is offline   Reply With Quote
Old 05-15-2013, 12:17 AM   #5
@mgaw23
@mgaw23's Avatar
@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute@mgaw23 has a reputation beyond repute
Yes please
2003 alero 2.2 ecotec tinted windows, cold air intake, strut bar, full pacesetter exhaust, HID lights, grill mesh, brembro brakes, kicker l7, chipped and more but looking for more mods i would like to keep my car luxury, clean and a head turner.
i do auto detailing so my car is always spotless [SIGPIC]
@mgaw23 is offline   Reply With Quote
Old 06-13-2013, 10:46 PM   #6
spc2125
spc2125's Avatar
bump for messy how to. I uploaded the pics that I had left. I got a new laptop and dont have the pics with the boxes around the areas that are described.
If you have any stupid questions feel free to ask them here and they will be answered.
Its a real piece of cake install.
just call me "Doc"
Check out my alero!
