11-18-2012, 02:40 PM
I would like DRL's
Hi. I am living in Poland and we need DRL or 24h low beam lights, is it easy to make it ?
my alero has/had it, but right now my V6 engine is dead, and i purchased european version of alero - chevrolet with 2.4 engine for parts, i changed all wires, ecu, bcm, engine and transmission, and that car has not DRL, but i need it
any ideas?
Thanks for help
Tomek
more cars..... here .....
11-18-2012, 03:44 PM
11-18-2012, 04:28 PM
Yes, i found something similar, but maybe is something as regular DRL on hi-beam on 6volts, as i had ?
11-18-2012, 10:15 PM
could you not just install it on your fog lights, or ise some led strips somewhere?
11-19-2012, 03:04 AM
of course, i can use led strips, panel led lights etc. but i would like to have as factory DRL, is it programmed or it needs some special module box.
11-24-2012, 03:07 AM
All aleros have DRL's. on 99-02 models the high beams were set for them then 03-04 they were switched to low beam drls. so if everything is put together right they should work. if not you could wire something into the parking lights to run for them (dont quote me on that, its been a while) fogs wont work because they dont come on with the stock drl set up.
03-02-2013, 01:52 PM
I did it , purchased BCM + ECU from USA version
right now whole engine swap from 3.4 into 2.4 has complete
everything works, next step is turbo
03-02-2013, 02:02 PM
pics of car?
Originally Posted by Oldsnut
Originally Posted by tipnitty
03-02-2013, 03:18 PM
my car:
03-02-2013, 04:20 PM
i demand more! can i see a side view, back, maybe a hood shot?
03-02-2013, 04:50 PM
The simpliest way:
https://picasaweb.google.com/1097056...o0712CAProject
some new pics (engine) i will make tommorow
03-02-2013, 04:56 PM
im really diggin this... pretty awesome. what made you choose the paint sceme though?
03-02-2013, 05:05 PM
outside a car?
03-02-2013, 05:57 PM
What are the specs on the subwoofer?
03-02-2013, 06:53 PM
Originally Posted by tomekbrek
outside a car?
yes your cars paint job, what made you go that route?
03-03-2013, 07:50 AM
That one on pics ? White one is Lotus SW250/1: http://www.seas.no/index.php?option=...ers&Itemid=268
next one is Brax Matrix 10.1
03-03-2013, 07:53 AM
I am a Brax Team member from Poland, and i did whole car on Brax products, speakers, amps, accessories etc.
03-03-2013, 08:24 AM
it was, 3.4 V6 '99 (original picture when i bought that alero)
swap engine 2.4 '99 + ecu&bcm '02
Only i have small problem with oxygen sensor, becouse engine has 1-wire oxygen, but ECU wants oxygen with heating, tommorow will try put some resistor for simulation, or... i do not know yet
03-03-2013, 01:06 PM
oh cool, very interesting!
04-17-2013, 09:01 AM
Ok wanna bring this back to topic.
He switched the BCM and ECU for the US versions ones. But what I still wonder is there a way to get the export models to run the DRL or not?
As far as I found out NONE of the export models ever had DRL or something like that.
What else is used in the DRL setup?
Thanks Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
