06-05-2013, 10:35 PM
#21
Hahah I've never posted on GAGT.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
06-05-2013, 10:38 PM
#22
Yes I know lol. I first saw your tutorial on GAOC and then I also came across it here on AleroMod
Customized 2003 Pontiac Grand Am SE2 3.4L V6
Mods: SC/T Spoiler, Tinted Out 20%, Cat-Back Exhaust, Amber Grille Lighting, Pioneer AVIC-940BT System, Live Traffic, XM Radio, Rear-view Camera, Black Front Bra, black bumper grille, Black Stubby Antenna, Michelin Defender Tires...
06-05-2013, 10:44 PM
#23
I personally just recommend doing all suspension work and then have the car aligned.
Yeah....I did that the first time when I changed the struts, sway bar, lateral links, and trailing arms, but the shop couldn't get the rear end to align within specs for some reason. I'll probably use a different shop or the dealer this time around after doing the rear disc brake upgrade.
06-05-2013, 10:47 PM
#24
Originally Posted by ItsMeScottG
Damn I wish I would have seen this info before. I started my rear disc brake conversion today and the dorman cables that I bought were about 2 inches too short. I ended up going to NAPA and the parking brake cables that I bought from them worked perfect.
I should have everything I need in order to finish the job now.
I missed that too, but fortunately the cables I ordered are from AC Delco.
06-05-2013, 10:48 PM
#25
Starglow, is your car lowerd?
06-05-2013, 10:53 PM
#26
I think I may have the installation done tomorrow. If not tomorrow than it should be done by Friday for sure. I aleready installed the PFYC Strut Braces. I'm currently just installing the rear disc brakes with the stainless steel lines and installing the front and rear PFYC Sway Bars. I really hope I have enough time to get the job done tomorrow.
06-05-2013, 11:20 PM
#27
No...it's stock height. Cars will easily bottom out on our driveway at normal ride height, so lowering the GA even more would cause many problems for sure.
06-05-2013, 11:23 PM
#28
Have you installed the front sway bar yet? If not then you're in for a real treat!
06-06-2013, 03:44 PM
#29
I have the same issue with my Cutlass... they told me that my bolts have to be cut. IDK why. I went to another place and they got it almost aligned... it's off in the rear by 0.001
I say just make sure all the bolts and stuff is the same.
1996 Infiniti G20
