07-25-2013, 08:45 PM
#21
13 inch rotors require 17 inch wheels.
I'm not too sure about the shift points. 5800 is way too high, I'd say around 5 grand, maybe 5200 or so. After a certain point in the RPM scale, the car stops making power and starts to fall off.
Spinning off the line? Those 60' are pretty bad. On a hot day when Redog is turning a 15.6 it's getting those kinds of 60's My best 60 was 2.09
07-25-2013, 09:06 PM
#22
Yeah i wheel hopped on like 3/4 launches lol. And okay ill try shifting a little lower next time.
Plus it spins/chirps a little going into second gear.
It was 73* out, last run it was about 67*.
I hopped mostly through 1st gear, but i didnt let out, yet ran my fastest time of a 15.1
Originally Posted by Oldsnut
Originally Posted by tipnitty
07-25-2013, 09:23 PM
#23
Once your spinning, forget about a good time, doesn't matter what you do.
73 and 67 are real good temps for racing, what was the humidity and baro pressure. The lower the baro pressure, the denser the air, the fast run times. 30.00 is "sea level" baro pressure.
Yeah your going to need "racing" tires. I'm going to be picking up Connti DWS in stock size. Only $124 a tire and rated number 2 in the catagory
07-25-2013, 09:31 PM
#24
Yeah i cant really help the second gear chirp. Lol maybe better tires will help for track, im looking at what b888 suggested on page 1. Hoosier drag radial tires, with 17" rims.
As for humidity and all, im not so sure, i didnt check that.
07-25-2013, 10:25 PM
#25
Ok im at the track and the first run i ran was a 10.379 @ 69.27mph with a .7537 RT. 2nd run was 10.329 @ 69.71mph with a .5715 RT.
07-25-2013, 10:49 PM
#26
Work on them RT's!
07-25-2013, 10:52 PM
#27
work on dat wheel hop
07-25-2013, 11:00 PM
#28
It bogs really bad from 0-15mph then it picks up.
07-25-2013, 11:17 PM
#29
Drag tires needed
Spinning?
07-25-2013, 11:54 PM
#30
07-26-2013, 12:03 AM
#31
Wut
07-26-2013, 12:09 AM
#32
^^ lmao... talking about the other guys almost 1 second RT...
07-26-2013, 12:10 AM
#33
No its not spinning. Its like not enough torque
07-26-2013, 12:21 AM
#34
Oh yeah lol
You need a new tune, and not from mpracing...
07-26-2013, 12:35 AM
#35
Where should I get it from ?
07-26-2013, 12:37 AM
#36
Milzy or wot tech
07-26-2013, 01:40 AM
#37
Ok would they allow me to use my pcm to let them tune? Jw
07-26-2013, 02:54 AM
#38
They will send you a new PCM with a tune, then you send them your old one. You have to pay a core charge
07-26-2013, 02:55 AM
#39
^ bingo
07-26-2013, 03:02 AM
#40
Originally Posted by sleepyalero
Wut
Oh yeah lol
