Old 10-31-2013, 06:04 PM   #1
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Bad oil leak
Hey guys,
My car started leaking oil really bad today. I popped the hood open, and looks like the Oil Pressure Sending Unit is leaking.
Although this is not me, this video shows exactly what is happening...
Is this something I can fix myself, or should I take it in? What would be involved in the repair?
Thanks.
Done lost my mind
Old 10-31-2013, 06:14 PM   #2
You can easily replace the sending unit yourself.
Old 10-31-2013, 07:04 PM   #3
Wow man, first Ive seen of that! But hell yes, easy fix bro!! Threads in/out same as a normal bolt
Old 10-31-2013, 07:47 PM   #4
jhubbz
⌘ Irish Pride
jhubbz's Avatar
Just picked up a new oil pressure switch from local parts store and a special socket to get it off. It was pretty easy on/off. Total was about $20 for both.
I guess the connection between the metal threading and the plastic part wears down over time.
I was running on about a quart of oil toward the end.
Thanks for the help guys!
Done lost my mind
Old 10-31-2013, 07:59 PM   #5
Yup. Did you use teflon tape?
Old 10-31-2013, 08:18 PM   #6
I used that port to feed oil to my supercharger... only reason Im familiar with it! Like I said, never seen this happen before...ever!
Old 10-31-2013, 08:39 PM   #7
Neither have I
Old 10-31-2013, 10:38 PM   #8
exact same thing happened to me... when I put in my triple pillar pod with the mechanical oil pressure, I tee'd that and within a week I was spewing oil like crazy... had a spare one on another block I had, changed it out in about 10 minutes and no issues since!!
Old 10-31-2013, 10:57 PM   #9
Seen it. Happend on an old 305 I had in my old pavement pounder. Seen a few customers cars do that too. However not to the extent of an oil leak complaint. Just dirty and smelly. Mmgt, sent u pm to personal email .
Old 11-02-2013, 08:36 PM   #10
jhubbz
⌘ Irish Pride
jhubbz's Avatar
It had something similar to teflon tape on it out of the box.
Done lost my mind
Old 11-02-2013, 08:58 PM   #11
Oh okay.
Old 11-06-2013, 01:47 PM   #12
Revhappy
Revhappy's Avatar
Revhappy is on a distinguished road
Happened to me while driving last winter. Stupid me kept driving it. Got to my shop and because of that I have a constant ticking noise from the cams from oil starvation
Rev high, shift happy
Bronze Mist 01', 2.4L w/WAI, F+R strut tower bar, 20% Tint, Upgraded 16" factory aluminum rims, Crossed drilled rotors on all 4 corners, chrome muffler tips and 3000K HID fogs.
Revhappy is offline   Reply With Quote
Old 11-06-2013, 05:23 PM   #13
Wow that's a lot of oil!!
I see you already fixed it, but yeah, easy fix on the 4 banger. Little more involved on the V6 (more in the way and right by the starter)
