Old 12-05-2013, 02:28 PM   #21
mastershake
mastershake's Avatar
mastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond reputemastershake has a reputation beyond repute
you guys think my ultragauge could have had something to do with it?
when i first discovered it wouldnt start, i noticed the ultragauge's backlight was lit without the key in the ignition... so i unplugged it.. just went and tested it on my moms car and it doesn't work anymore
rip ultragauge.
mastershake is offline   Reply With Quote
Old 12-06-2013, 07:14 AM   #22
Could have. If it failed it could have broght down the comm circuits in your car. But things should have returned to normal shortly after unplugging it.
Old 12-06-2013, 07:19 AM   #23
Originally Posted by MilzyZ34 View Post
sounds like BS to me. The DLC (Data Link Connector) has 4 wires going to it ... one 12v power wire, two grounds, and one serial data wire. Sometimes it also has a 5th green wire, but I've never seen one with a grey 5v reference wire for it.
Serial data communication wire should have an average of 2.5V (aprox) on it. It's a 5v circuit.
Old 12-06-2013, 10:08 AM   #24
I bet the thing went through a CASE relearn and that's what the problem was..... but what the heck do I know
Old 12-06-2013, 12:41 PM   #25
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
Could be right about voltage on the serial data line. I don't test that wire for voltage, just continuity, resistance, and short to ground. With the output on that wire being a stream of data from the pcm, I just don't think measuring the voltage is the best way to test that.
I think it's pretty hilarious that the dealership is clueless when they are the most expensive option, and also the option people assume would be the ultimate solution to their problem.
www.milzymotorsports.com
MilzyZ34 is offline   Reply With Quote
Old 12-06-2013, 03:10 PM   #26
Many times iv run into the situation where the problem is no longer present and there's just nothing I can do. I could just throw an SDM in a vehicle for a history problem... But then we become STealerships. Can't determine the problem and then were idiots. No matter what they only care when u screw up.
