Old 11-23-2014, 08:17 PM   #1
Hammer
Hammer is on a distinguished road
Monsoon system replacement question. (Rear speakers)
I'm new to the forum so be gentle.
I have an 02' Alera coupe that I just replaced the factory head unit and removed the monsoon amp. I have everything wired up and good to go except for the rear speakers.
I put some Kicker 6x9s in and I need to know how to wire them. I would like to not have to run new speaker wire if at all possible.
Thanks!
PS: If anyone can tell me the pins for the tweeters on the Monsoon amp wiring harness that would be sweet too.
Hammer is offline   Reply With Quote
Old 11-24-2014, 03:56 AM   #2
Nas Escobar
Nas Escobar's Avatar
Well considering that you removed the amp, you're pretty much going to have to run new wiring. The actual hassle is not running the wire, but taking out the rear shelf. You have to take off the sides of the seat and the side trim on the C pillar (the piece of metal between the rear door or rear window and back window). You could run both left and right on the same side. It doesn't have to be ran parallel. I would recommend running it on the passenger's side, especially if you ever plan on adding a sub. The battery is on the left so that's where the power cable would go.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
Old 11-24-2014, 11:58 AM   #3
Hammer
Is there a reason I cannot just splice into the harness that use to connect to the amp?
I have replaced everything. Head unit and speakers. Can I not just run new speaker line from the exposed harness that use to connect to the amp to the speakers in the trunk?
Old 11-24-2014, 07:46 PM   #4
03Alerosil
03Alerosil's Avatar
No because the monsoon speakers are bi-amp meaning the woofer and tweeter run off separate wires whereas your new speakers take all their signal from a single positive and negative. Run new speaker wires. Ain't that hard
Stock 2003 3.4 alero. Pioneer 3400ub. Pioneer 4 way 6x9s. Pioneer 3 way 4x6s. 800 watt JVC amp powering 2 12" MTX Audio terminators.
Old 11-24-2014, 09:07 PM   #5
Hammer
But, as I mentioned earlier I have replaced EVERYTHING.
New Head Unit, new door panel speakers and new rear deck speakers.
So I found a wiring schematic online and I have successfully re-wired from the harness that plugs into the Monsoon amp. So I just had to run a few feet of new speaker wire from the harness to the two rear deck speakers. Now to figure out how to get the tweeters in the doors working and I'll likely replace them too.
Old 11-25-2014, 06:31 PM   #6
Nas Escobar
Get a crossover or wire the tweeters in serial
1996 Infiniti G20
Old 11-25-2014, 07:42 PM   #7
rocketfast321
rocketfast321's Avatar
rocketfast321 is on a distinguished road
The tweeters are connected to the 4x6s
rocketfast321 is offline   Reply With Quote
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
