Old 12-10-2014, 10:51 PM   #1
WreckItRoth
WreckItRoth is on a distinguished road
Intake manifold causing vacuum leak
Somehow my intake is cracked up beneath the fuel injectors. Has this happened to anyone before? If i buy a new manifold im debating changing to the 2.4 set up but i read that requires a couple changes on the cpu.
Last edited by WreckItRoth : 12-11-2014 at 12:09 AM. Reason: found actual source of problem 15 mins after posting
WreckItRoth is offline   Reply With Quote
Old 12-11-2014, 05:49 PM   #2
Cars today are not a simple engine swap like they were 30 years ago. If you swap the engine for a totally differnt one, you'll need to swap the PCM and possiblly the wiring.
The injector O ring needs a little bit of oil to seat correctly or you could tear the ring forcing it into place. I used 10w30, just take a drop and run your finger all around the ring. It also makes them easier to remove if that time ever comes and protects the O ring as well.
Oil weight doesn't matter. I just used what I had in the garage. DO NOT USE WD-40 OR ANYTHING LIKE THAT, it will destory the ring
Old 12-11-2014, 08:40 PM   #3
Starglow
Starglow's Avatar
Starglow is on a distinguished road
That's exactly the same process I used without any issues.
1999 Pontiac Grand AM SE - 3500 Swap
Starglow is offline   Reply With Quote
Old 12-13-2014, 08:37 AM   #4
3800l67gam
3800l67gam's Avatar
3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute3800l67gam has a reputation beyond repute
I used dielectric grease to seat the injectors worked fine.
AwesomeNess
3800l67gam is offline   Reply With Quote
Old 12-13-2014, 11:12 AM   #5
01OhioAlero
01OhioAlero is on a distinguished road
I had a problem with this on my 3.4, its different but check the fuel rail where the injectors go. Mine had burrs and all kinds of crap which caused the oring to go bad really fast, like 5 mins after start.
01OhioAlero is offline   Reply With Quote
