01-08-2015, 10:47 AM
#21
KY used to have emissions inspections about 10 years ago now but thank God they ended that nonsense! They determined it was a HUGE waste of money and didn't make any real difference in preventing pollution.
http://www.thenewspaper.com/news/06/678.asp
01-08-2015, 05:27 PM
#22
I don't mind inspection. The emissions are 2nd to California around all major cities in PA, because that's where the most cars are. Makes sense.
When I bought this Delta, it missed the cutoff for no more emssions by 2 years. Cars 1975 and newer need emssions, but back in 2011 cars/trucks 1975-1983 only got a visual emissions inspection. Emissions for anything 1995 and down it a royal PIA too. Car gets the tailpipe sniffer and has to be run on a dyno at 15 MPH for 3 cycles of 45 seconds each. Very few stations have this equipment anymore. 1996 and up (OBDII) just get pluged into the Commonwealth's computer to find any codes. Drive in with an SES light on in any car, Automatic fail.
Classic, Vintage, and Antique, you pay reg only once, however it's 3 times the amount of a regular car. Basicly, have the car more than 3 years with a classic, vintage or Antique tags, it pays for itself. However these cars are limited to 5,000 miles a year. Go over 5,000 miles, full emissions, which older cars will most likely fail.
Any car driven less than 5000 a year is exempt from emissions, however, drive less than 5,000 miles 2 years in a row, the 2nd year, full emissions.
I only put 3,100 miles on the Alero last year. It was exempt, however if I don't go classic tags, it will be full emissions this year. I know the car will pass with flying colors. Thats not why I'm doing the classics on it. The Delta, well the 307 is the 2nd worst emissions engine out there. The SB 305 was the worst. Plus the car had hot inspection stickers on it anyway when I bought it.
New Jersey is totally different. No saftey inspection, no emissions. Their inspection is: all lights work, and does the car stop between point A and point B. Weight isn't even a factor in there either. Car could be metal to metal brakes, but if it stops within so many feet, pass. My gf's car will now pass a PA inspection with flying colors, before I worked on it, it would squeak by.
IDK what NY laws are, but my first Delta came from Long Island. Needed $800 in repairs and still failed emissions.
01-08-2015, 06:36 PM
#23
Your emissions sound similar to ours in Ontario... need it to license a vehicle obdII scanners hooked up... lights on or any cleared codes in the last 2 weeks is automatic fail.. a friend had a sunfire that needed an oil pressure sensor... nothing to do with emissions yet cuz the light wad on she failed... they'll give you a temp pass 24hrs & 30km later but you have to have everything fixed for the next test... right now it's mandatory every 2 years on all cars 5 years and older...
01-09-2015, 02:44 AM
#24
Yeah, I more or less feel the same. Inspection is whatever, usually they never check anything past basic functions. MD is more rigorous, but they only check it once so it's fair game. However the emissions crap is annoying to me. The way VA does it is stupid. Virginia has 3 metro areas... DC metro (shared with MD), Hampton Roads Metro area, and Richmond Metro area. Only the DC metro area has to do emissions testing. I guess it can be argued that it's because it's close to DC but Hampton Roads is the other economic base in VA, similar to how MD has Baltimore.
Does PA do permanent emissions or are they stopped at a certain age?
I agree that dyno is annoying. We don't have it as bad though, we just get one dyno at 15mph and 25mph for readings. 96 gets plugged in, which they probably don't check much if anything. SES light is automatic fail, and they will check it to see if it has been cleared beforehand.
Here, it's a monetary exception, but we do it bianually in the whole area. MD is $500 to be exempt, VA is $750 to be exempt and I forget what DC does with that. It's a pretty dime though, DC has pretty high car fees, but VA taxes cars like they do houses. MD doesn't tax cars other than when they are registered.
Nice! How did you end up fixing that issue? Or were the stickers "purchased" for the car?
Oh and why are you tagging the Alero as classic?
Really? I knew they didn't do safety since 2010 because of the recession and all, but I thought they still do emissions.
NY does inspect, how strict, IDK. I know they do the 25 year thing for emissions, OBD2 check for1996 and newer, and they check diesels for emissions as well.
1994 Olds Cutlass Supreme
1996 Infiniti G20
1993 Chevrolet Lumina Z34
1989 Buick Regal Limited
01-09-2015, 07:01 PM
#25
Seems they are phasing out the older cars because there isn't too many of them left. Like I said in 2011, it was 75-83 only got a visual inspection to see if the emissions are still there
I bought the car like that. You have to know somebody to buy inspection stickers out the back door. I don't have that kind of connection
because it's 15 years old and I don't drive it that much anymore. I want to preserve it
Yeah Jersey is bad. Most cars that are bought in NJ and brought over to PA, fail inspection, and fail really bad too
Yeah IDK, but I know my first Delta cost $800 to get thru inspection
