Old 12-15-2016, 09:39 PM   #41
cavedewler
cavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these partscavedewler is infamous around these parts
Im surprised to see the rafters can actually hold that engine
cavedewler is offline   Reply With Quote
Old 12-22-2016, 09:19 AM   #42
Caboose73
Caboose73's Avatar
Caboose73 is on a distinguished road
Send a message via AIM to Caboose73
Ya it was fine and came out without damaging anything
Stupidity has an incredible ability to overcome almost any obstacle.
http://www.fquick.com/Caboose73
http://www.aleromod.com/forums/showthread.php?t=27805
Caboose73 is offline   Reply With Quote
Old 02-15-2017, 03:34 PM   #43
riceralero
riceralero is on a distinguished road
I'm happy that the rust came off!
2001 Victory Red GLS 2
SLP cat back system
Hot air intake
riceralero is offline   Reply With Quote
Old 02-15-2017, 05:34 PM   #44
Caboose73
Caboose73's Avatar
ya me to im progress has been slow over the winter but im just finishing up my remodeling of the garage this week then im going to pull in the alero and start tearing it completely apart so i can grind/sand all the rust off of everything and give it a fresh coat of paint and under body coatings
Old 04-14-2017, 11:49 AM   #45
Caboose73
Caboose73's Avatar
Ok small update i got slightly distracted by my jeep xj buggy project i started over the winter so the poor girls been put on the back burner off to the back corner of my driveway. This is how she sits now but i finally got sick of looking at the engine just sitting on the stand in the corner of my garage so i decided to tear it down and see what condition its in and if i can use the block. Starting off i might of got a little to excited and started mocking things up to give me some inspiration lol
Old 04-14-2017, 12:08 PM   #46
Caboose73
Caboose73's Avatar
Ok now down to business this is how it sits now
Started by taking off the old filter and draining the oil
Then striped off the thermostat housing then the water pump
Then i pulled off the crank pulley,timing chain cover and cam towers
And finally decapitated the bitch and took the head off and it looks like someone used that stop leak crap in the coolant at some point cause some of the passages are clogged up with something.
Old 04-14-2017, 12:09 PM   #47
00redse
00redse is an unknown quantity at this point
If you decide to part it out instead, let me know.
Otherwise though, I'm watching this with great interest.
00redse is offline   Reply With Quote
Old 04-14-2017, 05:23 PM   #48
Caboose73
Caboose73's Avatar
i came very close to parting it out a couple times last year cause my GTO and Jeep buggy are eating up most of my fun budget but i decided to give it one last go
Old 04-14-2017, 05:39 PM   #49
Caboose73
Caboose73's Avatar
Got the heads off and everything looks pretty good considering it came out of my old black 99 alero that had almost 200K on it. Heres the old heads next to the P&P heads with bigger valves i had sitting on the shelf from my last build.
And an up close view of the Intake and Exhaust ports
And now the rotating assembly i dont really know why i numbered the rods/pistons seeing as im going to be using all new ones but i guess it doesn't really hurt anything so why not lol
And finally the block looks great and should definitely be usable it doesn't have any dings or grooves in any of the cylinder walls at all
Old 04-15-2017, 10:40 AM   #50
00redse
Should flow pretty nicely. I'm a bit green with envy lol.
your cam profiles look nice. Does the intake cam have the power steering hex and cam position sensor pad?
Also, did I see you mention the 2.3 oil pump swap?
Old 04-17-2017, 10:35 AM   #51
Caboose73
Caboose73's Avatar
Ya i'm definitely going to do the 2.3 oil pump swap and probably do some crank work(reduce weight,knife edge and maybe an oil shedding coating). The cams will fit everything like stock its a custom grind sold years ago that i managed to grab before they stopped selling them. The grind is supposed to be really great on the street with boost but we will see after i get it all together and get some dyno numbers and compare them to the HO cams.
Old 04-19-2017, 09:50 AM   #52
riceralero
that gunk in the coolent system might be dex-cool if it comes in contact with air it starts to solidify
SLP cat back system
Hot air intake
Old 04-23-2017, 08:40 PM   #53
Caboose73
Caboose73's Avatar
That makes way more sense i didnt know dex-cool did that
Old 04-24-2017, 02:16 PM   #54
riceralero
https://www.youtube.com/watch?v=PbX4CuE8auY
this is what it looks like, with an explanation
SLP cat back system
Hot air intake
Old 04-26-2017, 06:27 PM   #55
Caboose73
Caboose73's Avatar
wow i didn't know it did that definitely not running dexcool in any car ever again
Old 04-26-2017, 09:47 PM   #56
Unless you have or had a bad LIM gasket (3400 V6), which could get coolant and oil vapor into places it shouldn't be, I wouldn't worry about it that much. You still have to change it, flush out the system after 5 years or 50K miles, though. And as far as I know, the formula was changed some years ago.
You do have to be very careful to keep air out of the system as well. The LIM gasket should be replaced with the Felpro upgrade when possible.
