Old 01-16-2016, 03:23 PM   #1
IRONDOG442
IRONDOG442's Avatar
IRONDOG442 is an unknown quantity at this point
Send a message via AIM to IRONDOG442
Can I use a MN5 trans in place of a MN4
I got a 2.4 LD9 Alero I want to put a LA1 trans in? I think the FDRs are the same, does anyone know if this is a direct swap?
IRONDOG442 is offline   Reply With Quote
Old 01-17-2016, 04:15 PM   #2
3500Alero
3500Alero is on a distinguished road
3400 trans has a different bell housing pattern than the 2.4l. So no it will not work.
2004 Olds Alero 3400 v6 15.32 @ 88.69mph Bone Stock
1999 Olds Alero 2.4 to 3500 swap (running), Ported heads. totaled by a honda
2002 GAGT 3500 swap. parting out
1993 c1500 turbo 3100 swap 5psi.
1976 Cutlass 350 olds stock for now
3500Alero is offline   Reply With Quote
Old 02-09-2016, 10:48 AM   #3
IRONDOG442
IRONDOG442's Avatar
I could have made it work if I cut part of the bellhousing out for a recess area for the starter, but its not worth it also it would look incredibly hacked. It would be easier just to swap internals. Thanks for the response 3500
