Old 03-05-2016, 07:53 AM   #1
03Alerosil
03Alerosil's Avatar
Camber
Hey guys,
I'm having some alignment issues on myour 2003 Alero. Mainly the rear camber from the car having 167,000 on it and my twin 12 inch subs in the trunk. It's negative enough to make my tires bald on the inside within 30k. Are the strut holes oval? I hear cam bolt kits are bad. Any idea what I can do? I also have a front caster issue on driver side that may require a subframe shift as the car was in an accident in that corner before I owned it.
Old 03-05-2016, 03:28 PM   #2
03Alerosil
03Alerosil's Avatar
Ordered myself some new monroe economy quick struts. I'm sure the mounts and struts need replacing too, not just the springs. Hopefully that fixes my camber issue even with the sound system
Old 03-06-2016, 11:28 AM   #3
you will have to have a proper alignment done at a shop after you install the quick struts. That's a good place to start. The sound system shouldn't cause that. Check your control arms. I went in for an alignment once, 6 months after just getting one, and found that one of the rear control arms was bent, really bad. Upon getting it repaired the car drove a lot better, but I had no idea before that, or how it happened.
Old 03-06-2016, 03:35 PM   #4
There is no camber adjustment on these cars. Simply bolt it up and it should be in spec - considering the parts are in good condition.
Usually, cars that have no camber adjustment and are out of spec need new strut assemblies to correct the issue. In your case, new quick struts should do the trick.
Old 03-07-2016, 10:11 PM   #5
03Alerosil
03Alerosil's Avatar
All the arms are good. I've had to replace one of the in the rear already because previous owner thought it would make a good pull point. Man my rear toe was waaayyyy off. I don't even know how the car even went down the road.
I'm hoping this fixes my issue. I'm also installing new sway bar links up front with poly bushing and 2 new moog control arms up front as my right side one has a bad bushing. I'm not screwing around trying to replace just the bushing. Whole new arm is the way to go, especially on a car with 167,000
Old 03-10-2016, 11:43 AM   #6
03Alerosil
03Alerosil's Avatar
Decided to work on my car today. Got new rear struts installed. Took around an hour with hand tools. Gotta love assembled struts!
Took a measuring tape now that I'm done and instead of sagging in the rear my car now sits 1.5" high in the rear like most aleros I have seen.
Taking a short break to level out my blood sugar and it's time for the front
Old 03-10-2016, 02:24 PM   #7
falloutboy
falloutboy's Avatar
don't forget to take pics
Thanks
Julian
1995 Chrysler Stratus LX
2002 Nissan Primera with CVT
Old 03-10-2016, 06:00 PM   #8
03Alerosil
03Alerosil's Avatar
Both front control arms and sway bar end links are now new as well as the outer tie rod ends. Went for a drive. Completely different car. Wow. Getting it aligned tomorrow but I got it close.
Old 03-14-2016, 07:12 PM   #9
03Alerosil
03Alerosil's Avatar
Well guys I guess I can add 2 new front wheel bearings to my list. Driver side making noise like rumble strips so I'm doing both. Got 2 timken ones off rockauto for $144. Only thing left original in the front end now are the struts
Old 03-21-2016, 07:36 AM   #10
03Alerosil
03Alerosil's Avatar
Got the wheel bearings in. Very easy job. I also installed my turn signal switch and wired a toggle switch by my shifter for the horn. Sure is nice having a horn back. Deer tend to not wanna move unless you have a horn
Old 03-21-2016, 09:58 AM   #11
Sounds like you just need a bull bar lol
Old 03-27-2016, 07:11 PM   #12
03Alerosil
03Alerosil's Avatar
Oh yea sleepy lol. That would look just bitchin' on an Alero
