09-03-2016, 03:52 PM
WTB: Rear strut tower brace
I have looked for one of these on the internet, and the only places I could find them they were out of stock or something. I tried amazon, but the third party seller must have screwed something up because it never came. Does anybody have one they would like to sell and ship to me?
Does anyone know of a place to get one?
Does a brace for a different vehicle fit?
Does a n-body brace for the front fit in the rear?
"Luna"- 2003 GL 4-Door 3400 sold 2023
"Katie"-2022 Chrysler Pacifica Hybrid
09-04-2016, 08:13 PM
Not all years of the GA's will work (without modification).. I think it was 03 and newer GA that was the same for rear. I bought a set that was for 99-02 GA and ended up having to cut and tap it to add in threaded rod and about an inch/inch n half spacer to get it right length. Front was fine though. Of course though it may depend on what brand you buy too.
edit:
Originally Posted by 01OhioAlero
LOL.. same one I have, and from the same seller.(though I bought front and rear as a set)
Edit 2: If you don't have a front STB yet, might as well do both.... they make a huge difference.
2001 Black GX Coupe 2.4l 5 spd, short shifter, trunk lid w/ spoiler (amazingly from same original dealership), hood struts, Cosmo Evolution SRI, front & rear stb's, GAGT mirrors, more to come
1998 Bravada
I love beer, lots of beers.. I have found dark beers to be my favored.. however Labatt Blue is my go-to.
09-04-2016, 10:02 PM
I already have a front STB. It's still in its box though, I'm waiting until I have both front and rear braces so I can install them at the same time.
The one in the ebay link says it's for Pontiac Grand Am from 1999 to 2002. That one will not fit properly?
09-04-2016, 11:22 PM
That's the same I have. I had to extend it about two inches (I know I said one inch before, I was mistaken) to fit properly. Unfortunately that's all that is available for the N-bodies anymore. Oddly enough, for the front STB the 99-06 GA is the same as all years Alero, but only the 03-06 GA is the same as Alero for the rear even though both are N-body.
They used a thread on the fittings that you can't get a coupling nut for.. otherwise it would be so easy to extend. It is pretty easy to extend still though, I just cut mine in the middle and tapped it and used threaded rod and a spacer to make the bar long enough to reach from one side to another. The bar is hollow so tapping is really easy, I tapped mine for 9/16-18 no need to do any drilling (hole is ~half inch), just tapped it. Here's links to what I bought to extend it
Bosch tap only cost bout two bucks: Bosch 9/16-18 tap
Threaded rod 9/16-18 one foot length bout three bucks: 9/16-18 one foot threaded rod
I used a coupling nut as a spacer.. but a pack of five cost twenty bucks, a simple spacer would do fine and (more than likely) be cheaper than a coupling nut. Just in case here's a link to coupling nuts.
9/16-18 coupling nuts
1998 Bravada
09-05-2016, 10:20 AM
I feel like if I had to extend it I would screw it up somehow. But unless someone could sell me something that fits properly, I'll have to try it.
09-05-2016, 11:38 AM
Since no drilling is needed, I highly doubt you would mess it up.. it took me maybe half hour total to do it (and I've never used a tap before).. and that included getting tools out, as well as putting them away and cleaning up. The bar is hollow aluminum, so no drilling needed, the tap I linked will self center in the hole with ease (I didnt even use a tap handle, I used a universal fits-all.. a.k.a. crescent wrench). Cut the threaded rod down to about 4-4.5 inches in length, thread into one side of bar 1-1.25 inch, add 2 inches of spacer (or coupling nut I linked which is like 2 1/8) then thread on the other side of the bar, and done.
Or, since I already have the stuff.. buy the STB, ship it to me I'll do the work, just pay me $15+ return shipping (will probably be cheaper to ship just the bar without the mounts)
1998 Bravada
09-05-2016, 05:22 PM
For your front 03 and up was cause of the movement of the alternator slightly. That's why some of them have the notch in them, all backs of all years should be identical.
09-06-2016, 10:17 PM
Originally Posted by Bahlzeron
Since no drilling is needed, I highly doubt you would mess it up...
... (will probably be cheaper to ship just the bar without the mounts)
I probably have the tools somewhere to do it myself. Thanks for the help, though, I appreciate it.
09-19-2016, 12:07 AM
I just cut mine
What did you use to cut through the metal bar? I just got all the parts but I have to extend it.
09-19-2016, 09:00 AM
It's just aluminum.. I used a hacksaw for the STB, and a grinder with a cutoff wheel for the threaded rod (hacksaw was taking too long on the threaded rod)
1998 Bravada
09-19-2016, 07:20 PM
Well somehow I managed to screw something up. (I've been good at that lately) For the front bar, under the hood, the bar ended up shorting out the alternator fusible link. Yay.
09-19-2016, 09:29 PM
I ordered front and rear in July. Received the front and installed right away. I am still waiting on the rear bar. Last report was 2-3 weeks away yet. Must be a slow boat from China
2004 Olds Alero Sedan 3.4L GLS
3.4L = 207.481 Cubic Inches for us Old Guys
09-21-2016, 09:13 AM
Did you get the straight bar, or the one that has angled ends/notch/bend?
Edit to add:
For your front, 03 and up was because of the movement of the alternator slightly.
geez, that bites. When I ordered mine back at the beginning of January, both shipped in the same package, and quickly too.
1998 Bravada
09-21-2016, 08:01 PM
09-21-2016, 11:03 PM
I just had the straight bar in the front, got it from amazon.
edit:
jlhog, have you installed your front brace yet? Did it destroy your wiring?
09-22-2016, 04:41 PM
edit:
Yes, I have the front installed. Its been in since July without an issue. I don't have much room between plug on the alternator and bar. But it works..
09-22-2016, 05:33 PM
09-23-2016, 01:29 PM
jlhog, looks like you have the bent type bar, not the straight one. I think you have yours in backwards (left is on the right, and right is on the left)... the bend I is supposed to angle the bar close to the firewall to clear the engine.
1998 Bravada
09-23-2016, 01:41 PM
You may be right on that. It had no directions and for some reason it went on that way. I will flip it around this weekend. It still clears the way it is, but more room would be better.
