Old 10-01-2016, 06:15 AM   #1
mutley666
mutley666 is on a distinguished road
Timing Chain
Hello all. Finally getting round to fitting new timing chain on my 2.4 ld9
Couple of questions,
I got new cam and crankshaft sprockets in the kit, should I fit these also?
If so I cant find the torque settings for the crank pulley or the cam sprocket bolts.
Any ideas folks?
Thanks.
P.S
I notice I need a tool to hold the cam sprockets and crankshaft pulley when tightening.
Is there a way round this? Dont want to buy the tools to do 1 job!!
mutley666 is offline   Reply With Quote
Old 10-01-2016, 09:46 AM   #2
Garion1076
Garion1076's Avatar
Garion1076 is on a distinguished road
I bookmarked this webpage years ago - very helpful info about the 2.4 LD9 engine: http://quad4forums.com/forums/techdata.php
There is a Fastener Tightening Specifications section that is pretty extensive - hopefully what you need is there...if not, someone else on this forum might know and answer.
2001 GL4, Midnight Blue Metallic, Neutral Leather Interior
Flux capacitor & plutonium spark plugs
Garion1076 is offline   Reply With Quote
Old 10-02-2016, 09:47 PM   #3
rocketfast321
rocketfast321's Avatar
rocketfast321 is on a distinguished road
I would do gears you that far into it. The gears done wore to the chain. My water pump is leaking, and I will have the shop replace everything.
rocketfast321 is offline   Reply With Quote
Old 10-03-2016, 12:28 PM   #4
Bahlzeron
Bahlzeron's Avatar
Bahlzeron is on a distinguished road
Did mine around the beginning of the year. Yes, put the gears and chain in as a set. There should be a piece of paper with a warning on it with the tensioner.. don't loose it. The tensioner comes with the plunger compressed, after the chain chain is installed and timed, you need to release the plunger on the tensioner.
2001 Black GX Coupe 2.4l 5 spd, short shifter, trunk lid w/ spoiler (amazingly from same original dealership), hood struts, Cosmo Evolution SRI, front & rear stb's, GAGT mirrors, more to come
1998 Bravada
I love beer, lots of beers.. I have found dark beers to be my favored.. however Labatt Blue is my go-to.
Bahlzeron is offline   Reply With Quote
Old 10-05-2016, 03:23 AM   #5
mutley666
Yep I think I will change everything.
seems silly not to.
My only question is do I need the special tools to hold the cam sprockets and crank pulley when tightening?
The cam sprockets I can probably do with the dowels in place but the crank is quite a lot of torque then another 90 degrees.
Has anyone done this without special tools?
Thanks.
Old 10-22-2016, 12:44 PM   #6
paul ron
paul ron is on a distinguished road
when should it be changed?.. aprox millage?
My 2000 is about 85,000miles now
paul ron is offline   Reply With Quote
Old 10-29-2016, 09:39 AM   #7
rocketfast321
seems silly not to.
Thanks.
The crank one just slides off
Old 10-29-2016, 09:40 AM   #8
rocketfast321
When the water pump goes out.
