Old 11-21-2016, 07:36 PM   #1
kbubb91
kbubb91 is on a distinguished road
ugh...another failure(12 volt Plug dont work)
so now i went to use my GPS when i was lost only to find out both of the 12VOLT adapters in my car dont work. i tried for about 5 minutes trying to get my GPS to charge up and no power. after cursing my car, i had to go to a gas station in the middle of no where and ask them how to get to an off ramp about 10 miles away...it was embarrassing and awkward. im about ready to kick my car off a cliff between this, the brake failure, and the cruse control failure
ok, now that im done venting, how do i fix this?
Gotta love the 2 door coup.
kbubb91 is offline   Reply With Quote
Old 11-21-2016, 08:17 PM   #2
1970cs
1970cs's Avatar
1970cs is on a distinguished road
#34 mini fuse underhood fuse box. Check that over to see if that's causing the issue!
Pat
1970cs is offline   Reply With Quote
Old 11-21-2016, 08:26 PM   #3
kbubb91
thank you so much, yes, pulled the fuse, fuse blew, got to run to walmart and get a mini 20A
Old 11-21-2016, 10:08 PM   #4
AleroCzak
AleroCzak's Avatar
AleroCzak is on a distinguished road
I had the same problem except I lost multiple fuses to a cigarette lighter that was probably cursed by a gypsy or something because every now and then it would just arbitrarily blow the fuse. It too me far too long to pinpoint the problem.
"Luna"- 2003 GL 4-Door 3400 sold 2023
"Katie"-2022 Chrysler Pacifica Hybrid
AleroCzak is offline   Reply With Quote
Old 11-21-2016, 10:54 PM   #5
kbubb91
i bought 120 mini set and 120 regular set fuses.
i paid about $4 a peice on ebay. should be all set to replace every fuse on the car when that shows up.
mini 120ct $3.69
http://www.ebay.com/itm/120pcs-Assor...4011073895 11
Old 11-21-2016, 11:00 PM   #6
kbubb91
regular 120ct $2.99 +1.40 ship
http://www.ebay.com/itm/301884385411...%3AMEBIDX%3AIT
Old 11-22-2016, 02:47 PM   #7
That01Olds
That01Olds's Avatar
That01Olds is on a distinguished road
This is why you always keep a good old trusty paper map in your car. Just in case lol. I had a similar problem back when I had my Intrigue. The guy who owned it before me had wired up some aftermarket fog lights and every once in a while when you would flip the kill switch for it, the car would blow a fuse and completely shut-off.
Had it happen going 55 on the highway once and the steering wheel locked up when it happened. Thankfully I was able to still pull off the highway safely and swap it out with a new one. I just drove around with extra fuses in my car all the time so I was always ready. Weird thing though is when I swapped those fog lights out for new ones, I never had that issue again.
That01Olds is offline   Reply With Quote
Old 11-22-2016, 10:47 PM   #8
kbubb91
when i get the fuse kits, im replacing all of the fuses, every fuse will be brand new(except the jumbo ones) hoping that might bring my cruse control back.
Old 11-23-2016, 01:53 PM   #9
zzyzzx
zzyzzx's Avatar
Those 12V outlets seem to frequently blow fuses because they way the socket is designed, it's actually pretty easy to short it out.
Old 11-23-2016, 08:44 PM   #10
That01Olds
That01Olds's Avatar
Don't blame ya there and here's hoping that it helps. I drove a car once that didn't have cruise control. It belonged to a friend of mine and he needed a ride to the airport. So I drove his car there and back. After that it made me realize that I never want to own a newer model car that doesn't have it lol. At least not one I'm going to drive daily.
Old 12-11-2016, 02:13 PM   #11
kbubb91
cruise control failure was caused by two 2A fuses in the passenger side fuse box
Old 12-11-2016, 03:34 PM   #12
That01Olds
That01Olds's Avatar
Glad to hear that you got it fixed and have cruise control back!
