Old 04-17-2017, 02:16 PM   #1
riceralero
riceralero is on a distinguished road
3500 intake manifold for 3400?????
http://montecarloforum.com/forum/fwd...p-power-46071/
i found a comment on here saying that i could bolt a 3500 intake manifold on in place on the current manifold. Will it work?
2001 Victory Red GLS 2
SLP cat back system
Hot air intake
riceralero is offline   Reply With Quote
Old 04-20-2017, 10:01 PM   #2
3500Alero
3500Alero is on a distinguished road
You can use a 3500 plenum on a 3400 but it is not exactly a direct bolt on. You will need an adapter plate for the throttle body, and to get the most out of it you will want a lx5 throttle body to bolt on to it. The fuel pressure regulator is in the way of bolting on the plenum and will need to be clearanced by notching the regulator bracket and or grinding the plenum neck. Also your coil pack bracket will not bolt up after but there are ways around that!
If you really wanted to the 3500 heads and lower intake will bolt to the block aswell.
2004 Olds Alero 3400 v6 15.32 @ 88.69mph Bone Stock
1999 Olds Alero 2.4 to 3500 swap (running), Ported heads. totaled by a honda
2002 GAGT 3500 swap. parting out
1993 c1500 turbo 3100 swap 5psi.
1976 Cutlass 350 olds stock for now
3500Alero is offline   Reply With Quote
Old 10-24-2017, 11:29 AM   #3
MilzyZ34
MilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond reputeMilzyZ34 has a reputation beyond repute
Send a message via AIM to MilzyZ34
http://www.milzymotorsports.com/3500...-3400-engines/
MilzyZ34 is offline   Reply With Quote
Old 11-13-2017, 03:15 PM   #4
riceralero
Thank you! If time allows for it I'll try it
SLP cat back system
Hot air intake
Old 11-17-2017, 11:41 AM   #5
BlackV6
BlackV6 is on a distinguished road
Ive got a whole 3500 top swap for sale with brand new MMS Stage 2 heads
and a brand new TCE throttle body
much cheaper than the link above ^^^
PM me if you are interested
BlackV6 is offline   Reply With Quote
