Old 05-22-2017, 06:01 PM   #1
Silver SLP
Silver SLP's Avatar
Silver SLP is on a distinguished road
Passenger door locks itself when door closes
As the title states, my passenger door locks itself nearly every time the door gets closed (ignition on or off). I took the door panel off, used WD40 on the latch, and the problem persists. Any suggestions? Thanks for the help in advance!
2004 3.4 V6 - 105k mi. - Jan. 2015 AOTM
Silver SLP is offline   Reply With Quote
Old 06-01-2017, 10:04 PM   #2
unchained01
unchained01 is on a distinguished road
replace the door lock or check the wiring to the lock mechanism could be a shorted wire
unchained01 is offline   Reply With Quote
Old 06-03-2017, 12:00 PM   #3
Silver SLP
Silver SLP's Avatar
Thanks for the reply. The issue isn't electrical, it's just that the lock lever above the door handle moves enough when the door closes that it locks itself. Any other ideas?
I took the door panel off and found that moving the door handle also pulls on the lock and releasing the handle makes the lock "lock" the door.
