Old 10-12-2004, 09:55 PM   #21
Alerosince99
the only purpose the cat serves is for emissions. In terms of performance it is just another restriction.
Old 10-12-2004, 09:58 PM   #22
Alerosince99
Originally posted by Crazytaxi37@Oct 12 2004, 04:21 PM
I love my TOG's. I little on the loud side but that may have to do with having no CAT.
I can imagine. I have my togs with a 2.5 inch carsound cat and it is loud as hell. My friends always know when I'm coming.
Old 10-12-2004, 10:00 PM   #23
Crazytaxi37
The Dark Lord
Crazytaxi37's Avatar
Crazytaxi37 is an unknown quantity at this point
Send a message via AIM to Crazytaxi37
It's a game of give and take. I gain HP, i gotta give up a lil torque.
Crazytaxi37 is offline   Reply With Quote
Old 10-12-2004, 10:02 PM   #24
green99gls
About how much performance should I expect to see when I put headers onto my current set up which is a naich cai and slp exhaust.
Both Alerosince 99 and crazy have TOG's right.
Old 10-12-2004, 10:06 PM   #25
green99gls
It would seem our cars would be very similiar alerosince99 if I get my headers. Roughly what are you runninng hp wise.
Old 10-12-2004, 10:07 PM   #26
Grouch
I'd say around a 20hp gain at the wheels with those mods. Springs dyno'd his car after he installed the TOG's and showed a 19hp gain at the wheels. I do not recall if he had a custom exhaust or intake. I'm thinking he did though.
Old 10-12-2004, 10:09 PM   #27
green99gls
Also is there a big difference between nickel coated and silver ceramic for the extra 200?
Old 10-12-2004, 10:14 PM   #28
green99gls
So your saying that just adding the headers gave him close to 20 at the wheels. This doesnt include the 4-5 should expect from adding the CAI and slp exhaust does it.
Old 10-12-2004, 10:15 PM   #29
Grouch
Old 10-12-2004, 10:15 PM   #30
Alerosince99
When I originally dynoed I hit right around 160. I did have a rather large exhaust leak at the time and they did the pull in I believe second gear. Third is one to one but it kept droping out. (poopy dyno operator) and they didnt have fans running in the front to create air.
I would guess with the exhaust leak fixed that Im about 165-170. I would love to dyno it again but that aint happening till the next round is completed.
Old 10-12-2004, 10:23 PM   #31
Crazytaxi37
The Dark Lord
you dyno'ed on a dynojet didn't you???
if so I was at 167.2 whp w/ just a cai and slp
Old 10-12-2004, 10:24 PM   #32
Alerosince99
yeah it was a dynojet.
Its all good as long as you stay with the same type so you can compare your past results.
Mustang dyno will typically read less and some will say it is more accurate.
Old 10-12-2004, 10:28 PM   #33
Alerosince99
Damn 167 with just intake an exhaust is pretty impressive. You must have a little bit of a factory freak. Heh or else I have a factory anitfreak! I may have to do one more dyno before the next round of mods. I dont think my base should be that far off unless something was majorily wrong.
Wish I would of had time to do a quarter this year. That makes it easier for comparisons.
Old 10-12-2004, 10:29 PM   #34
Crazytaxi37
The Dark Lord
Yes it is, that's what all my numbers are on.
The conversion is multiply the sureflow number by 1.1 to get your dynojet number.
152=167.2
Old 10-12-2004, 11:04 PM   #35
springs fastest alero
Senior Member
springs fastest alero is an unknown quantity at this point
this depends on what your looking to do with the car.
nickel is more for corrosion than anything
the ceramic is to hold in heat
the new ceramic does a killer job of that.
holding in more heat keeps exhaust gas velocity up which makes more torque
how much more? couldnt say I haven't done back to back runs with just changing between the 2 coatings.
ceramic also will not disscolor or blue like the nickel.
the runs I did with 18-19hp gains were with the nickel coated headers.
at the times of my dyno my car had CAI, tb, and exhaust before the header dyno for the base run
just headers were added between the 2 dynos
now sporting 3 pedals
<img src=\'http://invision.aleromod.com/uploads/post-25-1071111759.gif\' border=\'0\' alt=\'user posted image\' />
springs fastest alero is offline   Reply With Quote
Old 10-13-2004, 02:35 PM   #36
1WhiteOSV
so, would you say it'd be safe to just go w/ the nickel coated and save yourself the $200?
Old 10-13-2004, 02:41 PM   #37
smokinAMD
Did you have to run an o2 simulator since you don't have a cat?
Old 10-13-2004, 04:54 PM   #38
Crazytaxi37
The Dark Lord
Of course. If you don't, you will throw a code.
Old 10-13-2004, 05:00 PM   #39
smokinAMD
Ah, just double checking. The one off PFYC?
Old 10-13-2004, 05:34 PM   #40
Crazytaxi37
The Dark Lord
Yup
