Old 09-25-2005, 07:30 PM   #21
bigd6983
Originally posted by kampfer422@Sep 24 2005, 11:55 PM
well, upgrading is definitely needed. 8 gauge wire over a 3ft span is only good for like 600watts of power or less. Take a look at this chart and it will help you 12V Wiring Sheet ,so i would expect you need atleat 4 gauge, 0 gauge would be better. But you will be doing the big 3 upgrade which is alty to battert postive, negative to ground and alty to ground. I think also it is suggested you up the fuses also but thats just what one guy who was going to rebuild my alty said to take full advantage of the upgraded alty. Right now i bet you aren't even getting half the power that alty can give. My friend had a rebuilt 120amp alt for his camaro and that was such a good alt, when he turned on his headlights and gave it some gas, the interior lights actually got brighter.
lol dude if uve never looked at what has to be done compared to what should be done it aint that easy.........main power wire goes into the distribution block(NOT EASY TO REPLACE WITH A THICKER WIRE), alt to ground?????? dude its grounded to the block lol.......no wire there buddy.......ive never checked the battery to ground wire but im sure its pretty simple but like i said never looked at it........changing the alt out is easy...........but the wiring isnt........
Old 10-29-2005, 04:55 AM   #22
kampfer422
does anyone have a link for a 160amp alty for 04 V6 alero?
Old 10-29-2005, 11:26 AM   #23
jackal2000
jackal2000's Avatar
try ebay
Old 01-29-2006, 07:48 AM   #24
speg80
Just bought high output alt. How do I beef up wiring from alt. to battery? Can I run a direct line?
Old 01-29-2006, 11:03 PM   #25
bigd6983
thats the same question ive been asking....i think you can, but u would want to put a good size fuse inbetween it and the battery
Old 06-23-2006, 12:58 PM   #26
Is it easy to get the pulley off the alternator?
I have an aftermarket pulley on mine and want to keep it.
This is good becuase I want to paint the alt anyway
Old 07-02-2006, 02:17 AM   #27
-Alero-
-Alero-'s Avatar
yeah i cant get my pulley off
AUTOBOT
