Old 04-26-2005, 02:35 PM   #61
jiffy
I still need some help with that extended battery terminal, because I know its not supposed to look like how I have it set up right now...
Old 04-26-2005, 03:06 PM   #62
snake_eyes2
Originally posted by jiffy@Apr 25 2005, 03:24 PM
Also, I couldn't figure out how to get the original battery post out, so look at what the retard me had to do. How the hell do I get the post out (second pic).
Don't bother taking the post out, The easiest way to connect the battery to the amp is to just open the fuse cover under the hood (next to the airbox). There is a power wire run right there, unbolt (7mm) and put your crimp ring around that.
Old 04-26-2005, 03:07 PM   #63
snake_eyes2
I can post a pc after work today, wait until 6pm MST
Ciao
Old 04-26-2005, 03:25 PM   #64
BLK03GXS
BLK03GXS's Avatar
Originally posted by snake_eyes2+Apr 26 2005, 07:06 PM--><div class='quotetop'>QUOTE(snake_eyes2 @ Apr 26 2005, 07:06 PM)</div><div class='quotemain'><!--QuoteBegin-jiffy@Apr 25 2005, 03:24 PM
Also, I couldn't figure out how to get the original battery post out, so look at what the retard me had to do.Â;-) How the hell do I get the post out (second pic).
[/b][/quote]
If your using more then 8 guage wire then this isnt something that you want to do... that wire powers the enitre car... for all your power devices. DO NOT run power wire for amps from here... Go directly from the batt.
Old 04-26-2005, 03:35 PM   #65
jamcllw
You need to get something like this.
http://www.cardomain.com/item/STRBTGMT?ref=prgr
Old 04-26-2005, 03:48 PM   #66
jiffy
jamcllw - yea, ive got that (check my pic on the previous page). I have it hooked up completely wrong right now, but it works. I need to do it the right way though because this looks bum.
Old 04-26-2005, 03:51 PM   #67
jamcllw
You need to cut off the rubber around the the stock battery cable. Put it next to the battery and screw in the first part and then put on the power wire for the amp on the end.
