Old 09-24-2005, 12:18 PM   #1
brim
brim's Avatar
Figured I'd repost this if anyone's interested still
1999 model worked fine, GA's 99-00 I believe worked assuming it the same, as usual this is from my experience, it's been posted on gagt as well
disconnect the negative battery terminal
Located the BCM under the passenger side kick panel, remove the two bolts holding the plastic cover and pull down the BCM.
Locate the middle pin connection and unplug it, find the yellow/black wire and the light green/black wire that sits right next to it
Give yourself some room to work away from the BCM so that you have enough wire to work with and cut the two wires. With the two wires you have hanging off the plug, twist them together, solder them, use connectors to connect them. I covered the other 2 wire ends with electrical tape and wrapped them up.
Now plug the connection back in, recconnect your battery connection and voila, control over your headlights at night, parking lamps and low beams.
No More Auto Headlights
smirking is important
follow the titans
Old 09-29-2005, 03:45 PM   #2
mrmike
mrmike's Avatar
mrmike is an unknown quantity at this point
err whats a BCM? Maybe add some pics to make this a proper tut
mrmike is offline   Reply With Quote
Old 10-01-2005, 11:14 PM   #3
brim
brim's Avatar
body control module, it's the box that controls a bunch of wiring, after you tear the plastic cover off under the passenger kick panel it's in the center left area and on a little metal slide holder.
I'll get pics if i get a chance
follow the titans
Old 10-02-2005, 01:12 AM   #4
why would you want to turn off your auto headlights anyway? Its a nice feature imo. Just so you can brag that you played with the wiring in your car? Sure there are a few minor things not to be liked about it, but they are far outweighed by the benefits.
We once had a man come in the shop demanding for us to take off the feature on his car that turned the headlights on when he had his windsheild wipers going. We refused, its illegal to have your lights off with wipers on anyways. Some things need not be meddled with imho.
Old 10-16-2005, 03:33 AM   #5
Lolo
Could you get some pictures up?
Thanks
Old 10-27-2005, 12:09 PM   #6
brim
brim's Avatar
ummmmmmm k
yet again it's personal preference, I don't need my lights for every minute of shade or at dusk, if I use anything I can run my fogs and parking lights.
what are the perks? i suppose
1) less usage on the bulbs = longer life, same for drl being disabled
2) one less draw on the system in case of charging system problems problems
3) Removed for content...joke or not, it is not tolerated -Aleromod Staff
:lol2:
follow the titans
Old 10-28-2005, 03:39 AM   #7
alero35b
what is so hard about pulling the DRL fuse? this fuse also controls your automatic headlights if i am correct.
Old 10-28-2005, 02:12 PM   #8
sound_xtreme
sound_xtreme's Avatar
it's a large benefit for serious audio fanatics. That's why i did it. I bought the kit several years back though, and i can turn mine back to stock at the flip of a switch, although i never do. lol then again, i never drive my alero either soooo
Cardomain
Old 10-29-2005, 12:09 AM   #9
brim
brim's Avatar
who are the moderators for this little sub section of the forum again?
just curious since I'm wondering what i said that was so disturbing it had to be deleted from the site
and naich, if it isn't you, get a better hold on your moderaters. this poop has been and is still ridiculous
follow the titans
Old 03-18-2006, 02:29 AM   #10
what about disableing your DAYTIME running lights? anyone know how?
Old 03-18-2006, 01:07 PM   #11
eag182
find the other thread about DRL natedawg
Old 04-03-2006, 08:56 PM   #12
brim
brim's Avatar
I disabled DRL's a long time ago, pull the relay for them and then seperate the black case off the relay. Inside you'll see what looks like a little contact point. That piece is what is triggered and makes the connection. Wedge a small piece of paper in there to dumb the relay into thinking it made a contact and voila
follow the titans
Old 04-03-2006, 09:33 PM   #13
Lovestheh20
does this mod enable the use of your fogs in park?
Old 04-04-2006, 09:48 AM   #14
Coupe
You can buy the DRL kit from ZZP, i just bought one.
Old 04-10-2006, 03:42 PM   #15
brim
brim's Avatar
when you switch to just parking lights your fogs are available
follow the titans
Old 07-28-2006, 04:55 PM   #16
brim
brim's Avatar
someone asked me about the wiring, this is on the 99 alero
follow the titans
Old 11-10-2012, 01:25 AM   #17
Blackthunder99
Blackthunder99's Avatar
Blackthunder99 is on a distinguished road
We never got pics
Blackthunder99 is offline   Reply With Quote
Old 11-10-2012, 01:40 AM   #18
Back from the dead!
Old 11-10-2012, 01:48 AM   #19
Originally Posted by Blackthunder99 View Post
We never got pics
Good luck getting pictures on this thread...I have been on the site for almost 2 years now and I have never seen the original poster on the site since I have been here, this is an older thread that I used for reference, it says in the top left corner of every post and this thread was last commented on july 28,2006
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
