Panda... if you're Lows are the DRLs they probably aren't getting the full 12volts during the day.. that's TERRIBLE for you HIDs ballasts. Check to make sure it's 12v (use a multimeter), and if it's not getting 12v disconnnect them right away.
If it's not getting the full voltage you'll burn them up. |
so wait a sec.. i have an 03, if i was to get lowbeam HIDs, i'd have to change where my DRL are coming from too???
If you have low-beam DRLs you need to either pull the DRL relay to disable them *or* you can re-wire (or change the harness) so you have high-beam DRLs like the older models.
I'm swapping the harness in mine so I can get fog light wiring too. |
my 02 is high beams at a low voltage and my friends 03 is low beams at regular voltage
but try to figure that one out! just a different wire harness i guess, not a relay or anything |
Nah, it's not at regular voltage. There is a DRL resistor which drops it down.
My HIDs went nuts when my DRLs kicked in, so I just disabled the DRL by putting a piece of cardboard between the contact points inside the DRL relay.
Plus it looks awsome when I just turn my LED turn signals on when it gets a lil overcast out. |
In the models with low-beam DRLs you can just pull the relay. Mine hasn't been in since I got my HIDs.
how the hell can i turn off my day time driving lights
haha it pisses me off i wish i could do like a switch or something is thare a sensor going to the emergency break cuza if u put the emergency break one click they go off but ur break lights will stay on can i just by pass a SENSOR??
to disable them you clip/cover one of the prongs on your relay. cant remember exactly which one it is though off top of my head. yeah, its in the how to section
