-   -   Taillights (http://www.aleromod.com/forums/showthread.php?t=2412)
FormulaNERD 06-04-2004 12:20 PM
Originally posted by AnderbrA@Jun 2 2004, 04:06 AM
first off, i need a core, thats the main thing that holds it up.....if anyone can find a set of cores or can do without theirs, they will get done first.
ok, question, in rough estimation, how long would it take for you to do my inners, and then my outers, i can go without the inners and still be able to drive, but not sure about the outers, and this car is my daily driver
again, just needed an estimate
i'll also check on getting some tails from a junkyard, it's cool if the lense is cracked right b/c you replace it with lexan? just as long as the rest of it is intact?
and i know you have to custom wire the leds, no SVS light or anything? no blown fuses? whats the install like on my end?
AnderbrA 06-05-2004 01:15 PM
the tails making process isnt that long to start with, but it all depends on what you want, a set of clears i can normally have done in about a week,
as far as broken lenses, as long as the inside isnt messed up from water or scratched at all they are fine.
if you want the LEDs, it costs a lot more, and will take a while longer since i have to mount them in the assemblies and have to make the altezza assemblies.
theres nothing that the the tails will do to your car at all, the LEDs themselves have to be wired in so you will ahve to wire them, otherwise i would need the harnesses from the tails as well.
FormulaNERD 06-05-2004 04:36 PM
ok, i like the ones you did for b-spot, i'm looking for similar with leds, clear lenses and gunmetal paint (duplicolor) just so everything matches up.
can you pm with a price estimation, and eta IF i sent in cores? thanks.
